Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
  1. #1
    Alternate ATF App Tester
    Points: 50,969, Level: 100
    Overall activity: 0%
    Achievements:
    50,000 Experience Points Veteran 25,000 Experience Points 10,000 Experience Points 1 year registered
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    galaxy note,galaxy 8.9 ,nook color
    Problem with the battery
    I have the original note,I was happy with the battery life and now all of a sudden it started discharging at the speed of the light, at least it seems to me! :-( What I'm talking about is that with my phone sleeping, my battery discharge s to 50 in 3 hours. I tried to figure out if I changed my settings lately or introduced apps that could cause this, but I didn't. Idon't remember my screen light being so bright when I put it all the way down,I have the feeling that my light got stuck or I really don't know what to think about. !
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
    Life must be lived as play. (Plato)
    Ads
    Advertising world
  3. #2
    Achievements:
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    I used it a little bit, that's it...three hours later is dead again! :-(
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
  4. #3
    Points: 10,186, Level: 67
    Level completed: 34%, Points required for next Level: 264
    Achievements:
    10,000 Experience Points 5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    It kind of sounds like a battery issue, how long is it taking to charge before it reports full?
    Sent from my Galaxy Note 10.1
    Huawei S7 104 (BB)
    Froyo 2.2.2 S7V100R001C98B021
    SOC Rooted - link2sd
    Samsung Galaxy Note 10.1
    SS SsS oo
  5. #4
    Achievements:
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    2 or 3 hours as usual
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
  6. #5
    Achievements:
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    I had a problem similar with my Sony, and it turned out it was a syncing issue, a particular app was constanly trying to sync and would not allow the device to sleep. Once I figured out what it was, and that turned out to be an app installed by AT&T, I was able to root the tablet and disable the app. I know it couldn't be the same exact issue but it could be a similar issue. Still, it kind of sounds like a battery issue.
    Huawei S7 104 (BB)
    SS SsS oo
  7. #6
    Achievements:
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    What do you mean for a battery issue? That I need a new battery? I don't think so, it just happened from one day to the other one that my battery started discharging at this amazing speed,if the battery get used up it would slow down little by little, I think. . Besides, it charges as fast as ever. I've been going through all my settings , checking if I touched something or added something I didn't recall, that can cause the issue. The only think I can see is that my screen, that is set to 0 brightness is much brighter than I recall...we know well that the screen light uses up a lot of battery. I went to check what use up my battery and it says 53% screen .On my tablet where I keep the screen brightnesss half way up, the screen uses 19%. It looks like the screen light on my note got stuck and I cannot turn it down.
    Attached Images Attached Images
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
  8. #7
    Achievements:
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    I suppose if your phone isn't losing charge while the screen is off, like in standby it is using power normally, then you are likely right. I would guess you have shut the phone down, even removed the battery and reinstalled it. Does the auto brightness setting still work?
    The picture seems to adequately express your distress btw :-)
    Huawei S7 104 (BB)
    SS SsS oo
  9. #8
    Achievements:
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    It actually does loose power on stand by: it went from 96to 93 in half an hour in sleep mode while my tablet stayed on 55.I'm so frustrated right now that I would buy an I phone !:-D
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
  10. #9
    Achievements:
    18376
    Feb 2011
    Washington State
    1,653
    Thanked
    193 times
    Points
    10,186
    Level
    67
    Hauwei S7
    If you turn on airplane mode and let it sleep the battery drain persists? This is a strange problem, hope you can figure it out.
    Huawei S7 104 (BB)
    SS SsS oo
  11. #10
    Achievements:
    13442
    Jan 2011
    miami,fl
    2,099
    Thanked
    175 times
    Points
    50,969
    Level
    100
    I've tried a couple of things and I'm checking if anything is happening with my battery and then if nothing works I'll try resetting my note. I have to check but I thing mine is not the kind that if you reset it ,it bricks. Thank you Tom for trying to help......thank you G U R U S....how could I do without you,yes you JP,Spider!? :-D
    Samsung Galaxy Note
    Samsung Galaxy 8.9"
    Nook Color
Ads:
  1. Battery Problem
    By murnesty in forum Hyundai
    Last Post: 09-20-2012, 01:38 AM
  2. Battery problem
    By bluedreamer in forum WonderMedia Based
    Last Post: 02-27-2012, 08:27 PM
  3. Battery Problem ? Rom Problem ? Any people can help me, please ?
    By ranellucci in forum Gome Flytouch Problems
    Last Post: 08-21-2011, 12:51 PM
  4. problem with the battery
    By ramae in forum Coby Tablets
    Last Post: 05-12-2011, 02:40 AM
  5. Battery problem?
    By nhoncoop in forum Android Tablet Q&A
    Last Post: 03-14-2011, 10:35 PM
galaxy note 10.1 battery discharging
galaxy note 8 battery discharging
galaxy tab 2 battery discharging problems
note 10.1discharging
note 2 problem with battery
samsung galaxy note 10.1 battery discharging
samsung galaxy note 10.1 battery drain
samsung galaxy note 10.1 discharging
samsung galaxy note 2 10.1discharging
samsung note 2 battery discharging
samsung note 2 discharging
www.androidtablets.net 50387-problem-battery
