The manual only tells you about charging the battery for the first time.
Should I top up the battery when I have access to a power supply or should I let the battery go flat before recharging it?
Can I use the tablet on the power supply so that less use is made of the battery when I have access to a power supply or will it be harmful to keep the tablet connected to a power supply when the battery is fully charged?
3Thanks
LinkBack URL
About LinkBacks
