Results 1 to 3 of 3
  1. #1
    Junior Member Achievements:
    147008
    Oct 2012
    California
    Samsung Galaxy Tab 7.7 GSM
    ICS GSM Galaxy 7.7 Wifi problems with multiple APs with same SSID
    Hi all,
    I wonder if any of you are having similar experiences and refer me to possible fixes.
    When I am at a location where multiple access points (using wifi-analyzer I can see this) with same SSID such as airport lounges, my tablet cannot connect.
    It tries and drop off to "saved" state. The tablet works fine when single access points like at home or other small public places like small internet cafes.
    List of places that I have problem include SF airport, HK airport, Taipei airport and other US cities airport.
    Mine is GSM model 7.7 with ICS. I dont remember if previous firmware had same issue or not but I think it may also had these symptoms.
    Ads
    Advertising world
  3. #2
    Super Moderator
    Points: 18,840, Level: 86
    Level completed: 98%, Points required for next Level: 10
    Overall activity: 97.0%
    Achievements:
    Recommendation First Class 10,000 Experience Points Recommendation Second Class 1 year registered 5,000 Experience Points
    Awards:
    Frequent Poster
    77592
    Dec 2011
    Norcross, GA
    4,445
    Thanked
    841 times
    Points
    18,840
    Level
    86
    Transformer Prime & TF700
    Many if not most of those types of public hot spots require that you acknowledge some sort of use agreement. The only way to do that is to open a browser rather than trying to connect directly. It should present you with a check box to agree to the terms.
    Locked out of your Tablet? - Printing from an Android tablet (or phone) - Connecting to the Internet with no WiFi - Move/copy/cut/paste files to and from your tablet - WiFi connection issues - Getting Flash Player
    TF201 & TF700 (stock) with dock, .
  4. #3
    151645
    Oct 2012
    Galaxy tab 7.7 ics
    I've similar problem with vien64. I don't know whether they are multiple APs.
    As I enable the WiFi, it keeps scanning for all available SSIDs. When I pick up one of the available public SSIDs with status "saved, secured ....", the status of that SSID becomes "Not in range" and scanning stops and then after about ten seconds it starts again. Other than "Not in range" SSIDs, no more public SSID appears and scanning never stops.
    BTW, is there any way to stop scanning other than disabling the WiFi and starting again.
Ads:
  1. Android ssid
    By BOKA in forum Android Tablet Q&A
    Last Post: 02-04-2012, 03:57 PM
  2. Android ssid
    By BOKA in forum New Member Introduction & Site Assistance
    Last Post: 02-04-2012, 12:41 PM
  3. Replies: 2
    Last Post: 11-15-2011, 03:12 PM
  4. Can I have multiple email signatures for multiple gmail accounts?
    By DucatiRdr in forum Acer Iconia Tab A500 Forum
    Last Post: 11-13-2011, 03:38 PM
  5. does the t103 work with hidden ssid
    By soltner59 in forum Velocity Micro Tablets
    Last Post: 06-03-2011, 06:51 AM
atrix same ssid
galaxy 7.7 wifi problem
galaxy tab 7.7 cannot connect to wifi
galaxy tablet 7.7 wifi connection problems solutions
i cannot connect to the internet on my samsung galaxy 7.7 tab
keep+dropping+wifi+conection+on+galaxy+tab 7.7
samsung galaxy 7.7 connectivity issues
samsung galaxy tab 7.7 cannot connect to wifi
samsung tablet wifi problems ssid
tab 7.7 wifi keep scaning
wifi galaxy 7.7 problem
wifi multiple access points same ssid
Tags for this Thread
