Page 1 of 15 1 2 3 11 ... LastLast
Results 1 to 10 of 141
Thanks Tree10Thanks
Thread: FIRMWARE RELEASES: firmware files, benefits and bugs for the Flytouch2 v2 /Superpad 2
  1. #1
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    This post is intended to keep track of firmware releases, known issues and known fixes. Please post comment on any additional firmware that you have tested for this device that is not listed, also any bugs or fixes that have been missed. NOTE: These links are not provided by me, but have been tested by me.
    20110302 (Supposed Offical Manufacturer Firmware update #3)
    Link: Deposit Files
    Mirror: http://rapidshare.com/files/45354062...te-3-Flash.zip
    Tested by: Chandos
    Fixes:
    - Adobe flash player 10.1 installed.
    - See this thread for more info on Flash: SuperPAD II Adobe Flash Support Questions
    - Smoother user experience
    - Market does not show all apps
    Issues:
    - Angry birds and some apps wont install. Remove sdcard to resolve.
    - Screen is still dimmer
    - Audio speaker output is low
    - Flash is black and white and choppy
    - Causes issues with pads with new screen 1024x576 resolution.
    20110316 (Release #2 with Brighter Screen. origin Unknown)
    Link: Disco_10inch_android2.2_20110316_Bright screen.rar - 4shared.com - online file sharing and storage - download
    Tested by: Chandos
    Fixes:
    - Screen is brighter
    Issues:
    20110328 (Supposed PRERELEASE BETA Official Manufacturer Firmware update v4.9)
    NOTE: This is not an official firmware release, but a beta release of the upcoming #4 official release.
    Link: http://depositfiles.com/files/m3ce3l1bx
    Tested by: Gundamboyx
    Fixes:
    - Unknown
    Issues:
    - Firmware version shows as 20110316
    20110410b (CUSTOM ROM: Tim: Release 2b. Based off the 20110405 TCH ROM and 0302 and Dutch v4 Official ROM)
    Link: http://public.timduru.org/Android/Fl...0410_Tim2b.zip
    Tested by: Maildrop, Chandos
    Fixes:
    - Fix for the wrong colors in browser & apps
    - Increased sound volume from speakers
    - Ad-hoc wifi networks
    - Market 2.2.11 - Showing many more apps than previously.
    - Youtube 1.6.21 working great, fullscreen HD
    - Woking GPS with google maps & co (Chandos: Used GPS+CoPilot to drive to work, worked perfectly)
    - Updated framework & libs
    - Dalvik cache
    Issues:
    - Some apps fail to install unless you remove the sdcard.
    - Calendar Sync gone.
    - Color issues persist in Opera Mobile
    20110419 (CUSTOM ROM: thechillhacker (TCH) , Based Off his 0413 ROM)
    Link: http://thechillhacker.com/media/19Apr2011.zip
    Tested by: Chandos
    Fixes: (Same as TCH 0413 ROM plus)
    - More speed increases from VM heap size optimization
    - SD card access tweaks
    - Some library updates
    - Compiled a new busybox static binary (1.18.4) with all the trimmings, That should help with the Titanium errors and other things.
    - Compiled a new WPA_Supplicant (from AOSP git repo) to allow for all WPA variants while keeping ad-hoc support. Compiles and runs fine but still does not scan networks properly - I'll come back to this.
    - Compiled an entire AOSP kernel source tree (for the modules).
    - Touch screen calibration comes up on first boot now
    Issues:
    - Titanium Backup crashes when You try and restore some apps (Generally the ones that require sdcard removal)
    20110430 (Supposed Offical Manufacturer Firmware update #5 for 1024x576 pads)
    NOTE: ONLY use this firmware on 1024x576 resolution pads.
    Link: http://depositfiles.com/files/sk26eywc6
    Tested by: Untested
    Fixes:
    - Screen resolution issues for new screen 1024x567 resolution.
    Issues:
    20110521 (CUSTOM ROM: Tim: Release 4e. Based off the 20110503 firmware)
    Link: http://public.timduru.org/Android/Fl...0601_Tim4e.zip
    Tested by: Chandos
    Fixes: http://public.timduru.org/Android/Fl.../ChangeLog.txt (Same as version 3,4a,b,c,d plus)
    - added apn telephony db (should allow to save apns)
    - changed kernel to 3d (should fix battery stats issue)
    - added back talk app + g* misc apk
    - declare system hw gps capability back
    - added isofs.ko module (use busybox mount to loop mount iso )
    - /dev links added for loop devices
    - added different tun.ko module
    - added bluetooth drivers + Gscript to load drivers
    - added missing noatime on internal mmc
    - Windows Network Shared drives support (cifs) (use the app CifsManager for easy mounting)
    - NTFS drives support(use the "mount usb drives" Gscript to mount)
    - Gscript to mount usb drives (mostly useful for ntfs usb drives)
    - Added GScript to load the usb wifi sticks drivers Realtek 8192cu and RAL rt5370 (Load more drivers Gscript)
    - Added back gps-status, spareparts, filemanager
    - Issues of Apps installing to /local instead of sdcard
    - Speed improvements
    - Most Huawei 3G sticks support
    - Flash support for full screen videos
    (still requires a lot of cpu to work, but should work better and fullscreen for most videos,
    make sure you don't have other cpu eating apps running at the same time or it tends to be unstable)
    - fixed installation failed error -18 requiring to remove SD card for certain applications (Angry birds...)
    - backported 16GB tablet format partition fix for Market (refusing to install)
    - added tun.ko kernel module for certain VPNs
    - media scanning Off by default (use Gscript to activate it back, or use QuickPic for Pics and video browsing, and ccplayer for music, faster ! )
    - internal SD card free space is now at /mnt/sdcard and external SD1 is at /mnt/sdcard/sdcard1
    - ask before doing media scanning on SD card insertion
    - updated youtube app to 2.1.6
    - Better Keyboard 8 as default
    - added init.d structure call at boot time
    - updated framework and libs
    - Turned ethernet off and wifi on by default
    - added cpunotify
    Issues:
    Unknown as yet.
    20110712 (CUSTOM ROM: Tim: Release 5a. Based off the 20110530 firmware)
    Link: http://public.timduru.org/Android/Fl...0712_Tim5a.zip
    Tested by: Untested
    Fixes: http://public.timduru.org/Android/Fl.../ChangeLog.txt (Same as previous versions plus
    - Gscript to fix newer models 2Mp camera issue.
    - Patched libigps.so for quicker gps location fix after 1st fix.
    - Merged back the official firmware 20110530 useful modifications
    - Updated framework & optimizations
    - Updated apps
    Maps
    BetterKeyboard
    DolphinBrowser
    LogViewer
    - Vpn fix. (PPTP with or without encryption reported to work, OpenVPN most likely not working, please report.)
    - Zipaligned video player & ccplayer by FlanFinger
    - Deactivate MyPad application by default (Buggy to mount/unmount and see external medias)
    - Add GScript to reactivate MyPad application (better use FileManager, use MyPad at your own risk)
    - Settings.apk with more features unlocked by UncleRus
    - Add TtsService.apk back
    - Add NetworkLocation.apk
    Choose the firmware that fixes the issues that most annoy you!
    REMEMBER: Back up your device before doing any firmware updates!
    Ensure it is a Flytouch2 v2 / Superpad II that you actually have: Most of us have pad Model: Disco. These firmwares DO NOT WORK with Model: SAWEE10 OR P041 (Commonly referred to as jpad and usually comes in a Superpad III Box) There is a totally different firmware set and method for updating the SAWEE clones. Please read this thread:
    Fake Flytouch 3 Guide: Superpad III, Jpad Sawee10 Beware - Android Forums
    HOW TO INSTALL: For questions and instructions on how to install firmware updates, please refer to these threads:
    Firmware update method for SuperPAD II
    Warning about firmware: Avoid flashing 'bootloader-discovery' to your device
    mobilemonger, alex1640 and vaskodj thanked this.
    Ads
    Advertising world
  3. #2
    Moderator
    Points: 13,138, Level: 74
    Level completed: 72%, Points required for next Level: 112
    Overall activity: 9.0%
    Achievements:
    Veteran 25,000 Experience Points 1 year registered 10,000 Experience Points 5,000 Experience Points
    14884
    Jan 2011
    Pennsylvania
    529
    Thanked
    57 times
    Points
    13,138
    Level
    74
    HTC ONE, Droid Razr, Galaxy Tab3, LexiBOOK
    Good Post! Keep it updated.
    jondj1205 thanked this.
    No matter how much mud slinging and flaming that happens, competent devs shouldn't be banned. That's straight-up bs.
    --Devices--
    • HTC ONE "Everything Your Phone Isnt"
    • Galaxy Tab3
    • Droid Razr
    • Xperia U
    Glitcher,Modder,Themer,Developer,Hacker,Enthusiast
    |HMU on Google Wallet for a donation if you support my work! rgocal09@gmail.com|
  4. #3
    Junior Member Achievements:
    22798
    Mar 2011
    9
    When i updated april 5 firmware mobile network doesnt work when open got error and close it
    Sent from my Flytouch3 using Android Tablet Forum
  5. #4
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    Some notes on the 20110410 Custom ROM by Tim
    Market
    If you're still missing apps in Market do the following:
    - Connect at least once with Market & your account.
    - Then go to settings => Applications => Manage Applications => All
    - find Google Services Framework from the app list
    - click on clear data + OK, then force stop
    Reboot.
    wait about 1 minute after you're back in.
    Start Market again. (if it crashes, wait a bit and try again, it should go through )
    Then you should see more apps after that, like google maps, Skype & such..
    GPS
    If your gps is stuck in Shangai or not updating,
    you need to reset the agps data with the gps status software
    in the menu => tool => Manage A-GPS state
    do reset + download
    Plug in your gps antenna, and let it run until you see it gets as many fix as it can,
    wait even more until you see the latitude and longitude changing. (it should reset when it grabs 3-4+ fixes)
    At that point you can run google maps and it should now have your correct location
  6. #5
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    Manufacturer firmware update 0328 v4.9 -I have just posted link above
    I have yet to try this. It is sourced from the apad tv forums and was released in last 24 hours. A few users there have tried it and noted speaker output is still at low levels, and performance seems maybe a bit better. There is no official word on the fixes and or issues of this firmware as yet, but I will keep it updated here when I find anything out.
    Words from the admin who posted the ROM: "It's currently under going testing, but I thought some users may want to test it out before it is approved"
    If anyone fancies trying it out, please post back your experience.
  7. #6
    25620
    Apr 2011
    Australia
    Super Pad 2
    20110328 (Supposed Official Manufacturer Firmware update v4.9)
    Link: Deposit Files
    Tested by: Untested as yet.
    Fixes:
    Unknown
    Issues:
    I Installed the above but the android version still has 2.2-20110316, any help would be appreciated
  8. #7
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    Thanks for the feedback gundamboyx, I have asked other users for feedback on their android version also to confirm. I have some more feedback from another user, can you confirm the below?:
    "I've tested the new firmware, it has a good video player (CC Player) but regarding to google account syncronization, it only syncs Picasa fotos and Gmail, callendar is not synced, i think it would be easy to implement that in the final release.
    It also lacks the Develepment submenu in applications, the Update application still throws an error code.
    I noticed an slight improvment in speed and touch screen response."
  9. #8
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    Some notes on the Tim 20110412 (2d) ROM
    Connecting to adhoc wifi network
    - Turn Off your wifi in the Settings => Wireless & networks
    - Wait that it's Off
    - Start the GScript Lite application
    - click on "Ad-Hoc support drivers or original drivers..."
    - Turn your wifi back on.
    It will switch to the adhoc capable network.
    Same procedure to switch back to the original driver.
    If it doesn't seem to work, you might need a reboot.
    Better not do the switch while you're using wifi too
    Make sure to turn wifi off first.
    3G / Telephony apps
    The apps are deactivated by default in this rom, as to avoid unnecessary battery draining.
    But there is a script that allows you to activate them back with one click.
    - Start the GScript application
    - click on "3G Telephony apps On-Off"
    You should now be able to go to the Mobile network settings and it should be fine.
    If it doesn't seem to work, reboot
    It has been reported to work with the 3G USB stick E1750 so far.
    Titanium backup
    Enable USB debugging to ensure it works properly.
    Shoutcast streaming
    Android 2.2 doesn't support aac streaming, so with the default apps you won't be able to play the streams.
    But there is currently a way around it, install the application 'TuneIn' from the market, and you'll be able to play all your streams with that app
    How to Manually install "Google Sync Calendar and Contacts"
    GoogleContactsSyncAdapter.apk
    GoogleCalendarSyncAdapter.apk
    http://wiki.cyanogenmod.com/index.ph...Latest_Version
    Find the download link at the very bottom right with Google App version "CyanogenMod 6" "HDPI version". Download the file. Unzip and find these two files.
    Download these two app to the /local folder of the FT3
    Open Mypad application.
    Browse to the files and double click them and allow to install.
  10. #9
    24566
    Apr 2011
    Australia
    131
    Thanked
    18 times
    Flytouch 2 v2
    2 new firmwares today, tim and TCH. I am currently trying tim2e. Pls post feeback if you try these. Tks
  11. #10
    1 year registered 500 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    27174
    Apr 2011
    Indonesia
    Superpad 2
    i can enjoy angry bird , when i upgraded to 20110416 Rom , please enable it
    thanks
Ads:
  1. Huawei Ideos S7 Official Firmware Releases Discussions
    By goodoane in forum Huawei Ideos S7 Technical
    Last Post: 10-10-2013, 12:21 PM
  2. [ROM] Gome Flytouch Firmware Releases (VIA8505 7" Tablet)
    By xaueious in forum Gome Flytouch Firmware
    Last Post: 03-08-2013, 01:44 PM
  3. My SuperPAD II experience (firmware post #17)
    By sinistersnipe in forum SuperPAD II Firmware
    Last Post: 01-24-2012, 03:12 AM
  4. Replies: 12
    Last Post: 01-07-2012, 08:53 PM
  5. Firmware update method for SuperPAD II
    By xaueious in forum SuperPAD II Firmware
    Last Post: 04-03-2011, 08:59 PM
firmware mypad 102
firmware update frf85b
how to check superpad firmware
mypad 102 firmware
mypad 2 firmware
mypad 2 firmware update
mypad2 firmware
myphone mypad 2 firmware
myphone mypad 2 firmware download
superpad ii apps
tim 4c rom
updates for 2.2-20110529
Tags for this Thread
