Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
  1. #1
    Senior Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    Sylvania Mini Tablet Express
    Parse Error: There is a problem parsing the package
    Dear Sirs, i actually like this tablet, done a lot of things, it was root and i removed some apps like telephone and so others to have a better battery life on it, but today i upgraded the market that came with it(slideme 3.5), and installed the 4.1 version, i also downloaded dolphin browser, however, after installing that app, i recieve some weird notifications regarding that some programs suddendly stops inmediately, so i got a little scared and did a uninstall the dolphin browser, then after doing that my tablet wont allow me to install nothing regarding in applications downloaded from the market, a new message appears on the screen saying this:
    Parse Error
    ...and then the ok box
    i haved tried to do a factory reset, but i did the factory reset, and nothing, the same messages continue to appear... i already found a way on the internet to make a hard reset presing the screen and simultaneously pressing the 2 buttons in the back or the tablet, and after doing that, a message on the screen appears saying that it didnt found any
    "no recovery image is found, try recover from sd"
    Is there anyway you guys can help me with it?? everything was working fine, awesome, but i did update the market and installed that dolphin browser, that is when this problems appeared
    I'll await your reply with great interest...
    Regards,
    JV90
    Ads
    Advertising world
  3. #2
    Points: 485,962, Level: 100
    Overall activity: 4.0%
    Achievements:
    Veteran 150,000 Experience Points 100,000 Experience Points 50,000 Experience Points 1 year registered
    Awards:
    Posting Award
    10570
    Dec 2010
    627
    Thanked
    185 times
    Points
    485,962
    Level
    100
    Sylvania SYNET7LP
    Quote Originally Posted by Jv90 View Post
    If you receive a "No recovery image is found, try recover from SD" message when following those steps, it is now possible to manually update the device to obtain a recovery image.
    How to manually update SYNET7LP/SYTABEX7/Disgo 6000 to Android 2.2 "Froyo" - Using a microSD card OR from computer using USB cable and OTG Port
    However, this will update your device to DG2.20 which is a different version of the Android OS and you will have to root again and make some of those same changes but the battery life seems to better without the need to delete phone.apk.
    If you want to stay on DG2.02 or DG2.01, you could just try clearing the data and cache in Settings > Applications for slideme.
    If all else fails and you want to stay on DG2.01 or DG2.02 try uninstalling slideme 4.01 and find version 3.5 to see if that fixes it.
    Another option, if you have root and RootExplorer some instructions say to delete /data/dalvik-cache. Not sure what this does but it gets rebuilt the next time the device is turned on which take a while and the Sylvania animation stays on longer before the launcher screen is display.
    Finally, if all else fails look for an alternative market like - getjar, or Amazon App, or the Ugly Hack method.
  4. #3
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    Thanks a lot cfrokit, i would do that and post the results, i really appreciatte it.... once again thanks
  5. #4
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    However? what is if i get another sy;vania of the same model, my sister has one too, could i copy some files into the sd card?? and then do something to restore mine??take a recovery image from the one that works??
  6. #5
    Achievements:
    Awards:
    Posting Award
    10570
    Dec 2010
    627
    Thanked
    185 times
    Points
    485,962
    Level
    100
    Sylvania SYNET7LP
    Yes, if it's slideme, uninstall on your device, get .apk from other device and side load via SD card.
    A recovery image has NOT been identified. Let me think about how we might apply the manual update method using some of the previous versions to see if something could be created without updating the device to the next version. Please see Post #47 [How To] Manually Update SYNET7LP/SYTABEX7 to Android 2.2 "Froyo" and then post your "hwver". Also if you could -
    Code:
    $su
    #getprop ro.build.version.release
  7. #6
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    Once agains, thanks a lot; i just root it again, and delete the files that you mention above (data/cache/), it took a little more time that it use to it to start; i would like to update to froyo instead the 2.1 that i have; however i cant understand some of the instructions thats mention on the link, i mean, i understand win7 and can do a lot of things, but i never mess on android os, this is my first tablet; so i really understand the windows instructions already, i will try to do the update as is mention on the link, but it seems a little ........
  8. #7
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    It Works cfrokit, thank thank thank you
    I manage to delete the files that you mentioned, and now i can download anything from the slideme market 4.1;
    Once again thank you
  9. #8
    250 Experience Points 100 Experience Points 31 days registered 7 days registered
    46709
    Aug 2011
    California
    29
    Thanked
    2 times
    Sylvania 7" SYNET7L
    Same error. Should I still upgrade with OTG, if I have the 10" model? Is there an OS to use for upgrading? I have all the ius betas downloaded for my 7"s.
  10. #9
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    I had that problem, and believe me, what cfrockit told to erase that particular folder its true, try to do it again, you'll have to root the tab first of course in case that you don't have it rooted, follow the instruction, to erase the folder install androot file manager over the market,
    Sent from my Sytabex7 Tablet using android forum
  11. #10
    27571
    Apr 2011
    Ecuador
    296
    Thanked
    38 times
    also, try to install beta4 os if you have the Sytabex7 version(whitout the hdmi), thats the one os that is working fine, the easy way to do it is via otg, and reinstall the os again
Ads:
  1. Replies: 10
    Last Post: 02-03-2012, 06:12 AM
  2. Tipstir's | Power Collection Package 228 | 1/21/11
    By tipstir in forum Gome Flytouch
    Last Post: 02-20-2011, 08:02 PM
  3. What is Android Package Installer?
    By New2Android in forum Android Tablet Q&A
    Last Post: 02-03-2011, 09:50 AM
  4. Parse Error
    By Skilover in forum Nook
    Last Post: 01-23-2011, 12:37 PM
  5. Tipstir's | Power Collection Package 101 | 11/13/10
    Last Post: 11-17-2010, 11:35 AM
android there is a problem parsing the package
parse error android
parse error there is a problem parsing the package
there is a problem parsing the package fix
what does parse error mean
what does parsing error mean
what does parsing mean on android
what does parsing the package mean
what does problem parsing the package mean
what does there is a problem parsing the package mean
