Results 1 to 5 of 5
Thanks Tree1Thanks
  • 1 Post By john_tartar
Thread: Sytabex7 2.2 wireless woes
  1. #1
    Junior Member Achievements:
    1 year registered 250 Experience Points 500 Experience Points 1,000 Experience Points 100 Experience Points
    29844
    May 2011
    Hello,
    this would be my first post here but I have been a long time lurker in these forums.
    Long story short i bought a Sytabex7 (mini tablet express) and upgraded to froyo.everything works fine except the wireless. The wifi signal stays alive and then once it goes to standby it does not wake up. I read the whole resources thread. Changed txpower to 20 and upgraded the wifi driver all to no avail. at this point i really regret upgrading because i usually use it in places where i need to keep disconnecting from one spot to another and this was not an issue before. did anybody every figure out a fix? any help would be appreciated in advance
    Ads
  3. #2
    29110
    May 2011
    78
    Thanked
    6 times
    Sylvania
    I have the same tablet, with the 2.2 upgrade.
    Mine drops the Wifi connection when it goes into standby, but once it comes back, it takes 30 sec or so to reconnects automatically.
    Maybe it's considered a feature, i.e conserves power when in standby.
    I imagine you could set it to never go into standby, then turn down the screen brightness to conserve power.
    cfrockit thanked this.
  4. #3
    Points: 485,962, Level: 100
    Overall activity: 4.0%
    Achievements:
    Veteran 150,000 Experience Points 100,000 Experience Points 50,000 Experience Points 1 year registered
    Awards:
    Posting Award
    10570
    Dec 2010
    627
    Thanked
    185 times
    Points
    485,962
    Level
    100
    Sylvania SYNET7LP
    Quote Originally Posted by kakuto View Post
    As mentioned by
    Quote Originally Posted by john_tartar View Post
    We're not alone with this issue/feature. Other infoTM devices (Flytouch II, WOWpad, SuperPAD) are plagued by the wifi, as noted in this post on one of the development sites xda-developers - View Single Post - [ROM]InfoTM X220 (Flytouch II, WOWpad, SuperPAD) and this thread on another site Setting WiFi on Superpad2 FlyTouch3.
    The suggestions gathered in the Resources for the SYNET7LP/SYTABEX7/Disgo 6000 are just that, suggested fixes to some common issues and may not work in every situation but new solutions are constantly being identified. Continue to scour all of the forums related to infoTM devices and Ralink wifi devices for other fixes that may work on your device. If we can combine our efforts to create a custom ROM that address our common issues we could all benefit with working wifi, auto rotation (orientation), automatic updates, working Market, Flash, more CPU resources, etc...
    One of the other files often associated with wifi issues is /system/bin/wpa_supplicant. In this thread they discuss replacing it with a patched version which also adds adhoc functionality Android Ad-hoc support hack/wpa_supplicant. However, this may introduce new issues when scanning. So if adhoc connections are not important, you may not want to try this potential fix.
    Another thought, since the infoTM family of devices all seem to be sharing the same base software but the physical hardware differs (Sylvania 10-inch Magni Tablet - SYTAB10MT (SYNET10LP), Fyltouch, SuperPad, etc.) all have a little switch to toggle the WiFi On/Off where the 7" doesn't have this option, could this be messing up the 7" coming out of standby and failing to connect to a weak signal?
    Also, with the common software the 7" devices think there is an Ethernet port where none really exists. The programmers have left eth0 turned on by default. Could this be an issue that could be resolved by turning off reference to eth0 device? In this firmware update, for another infoTM device, in the /system/app folder there is a EthernetSettings.apk application which can be installed on an updated 2.2 Sylvania device that will allow the Ethernet port to be turned off.
Size:  2.9 KB Name:  Settings.JPG
Size:  32.9 KB Name:  settings_db-secure.jpg
    Finally, there is a reference to wifi in the build.prop that is blank "ro.wifi.channels=". Does this have any impact to identifying available wifi? Several threads discuss modifying the build.prop for various reasons but with caution because many devices have been bricked by messing with build.prop.
    Updated: Attached EthernetSetting.apk
    Attached Files Attached Files
    Last edited by cfrockit; 05-10-2011 at 11:00 PM. Reason: Attached file EthernetSetting.apk
  5. #4
    3 months registered 250 Experience Points 31 days registered 100 Experience Points 7 days registered
    83263
    Jan 2012
    33060
    9
    sytabex7-2
    Finally got my sytabex7-2 to accept ad hoc network rooted with universal androot v1.6.1 from this thread and used zt-180 adhoc switcher from slideme app market worked like a charm. Havent tested txpower mod if someone does let me know it doesnt destroy anything.
  6. #5
    7 days registered
    83657
    Jan 2012
    us-ky
    9
    sytabex7-2
    does anyone have a usb ethernet hub to test on the sytabex7-2? if it works i will be ordering one for faster download/upload speeds at home. thanks
Ads:
  1. Perhaps some modifications to sooth your USB charging woes?
    By Childofthehorn in forum Augen Gentouch
    Last Post: 11-26-2011, 10:33 PM
  2. iMito iM7 woes..
    By magnus_olsson80 in forum Telechips TCC8902 Tablets
    Last Post: 07-06-2011, 12:55 PM
  3. SYTABEX7 NOT SYNET7LP users needed
    By st0ne in forum Sylvania Tablets
    Last Post: 04-12-2011, 02:57 PM
  4. Unsure about the SYTABEX7
    By Malarky in forum Sylvania Tablets
    Last Post: 03-28-2011, 08:33 PM
  5. Replies: 0
    Last Post: 12-27-2010, 12:04 PM
sylvania model sytabex7-2
sylvania sytabex7 2
sylvania sytabex7 2 reviews
sylvania sytabex7-2
sylvania sytabex7-2 tablet
sylvania tablet sytabex7-2
sytabex7 2
sytabex7 2 problems
sytabex7-2
sytabex7-2 troubleshooting
sytabex7-2 wifi
www.androidtablets.net/forum/sylvania-tablets/14386- sytabex7-2-2-wireless-woes.html#post86136
