Results 1 to 10 of 10
  1. #1
    Junior Member Achievements:
    9910
    Dec 2010
    Hilo, HI
    Elocity A7, Samsung Captivate, Sylvania
    Battery no charging
    So first of all yes I did update to 2.02 uninstalled phone.apk, bluetooth.apk, and cellphony(whatever).apk
    After updating had the device off and plugged in for 6 hours. Unplugged it and it wouldnt power up.
    Plugged it in and it powered up and said that it had a 30% charge.
    Ran it till it died and plugged it in again. Powered it on, and left it charging while on for another 6 hours.
    This time said it had a charge of 15%
    I am going to try to update again after work, but I doubt it will work. Does anyone have any ideas or do I just have to return it?
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    500 Experience Points 1,000 Experience Points 250 Experience Points 100 Experience Points 3 months registered
    9788
    Dec 2010
    Houston Texas
    102
    Thanked
    8 times
    SYNET7LP
    I had this problem before upgrading. I would try to recover it first, Android if that dosent work, i would exchange it for another one.
    sent from my android tablet
    SEARCH IS YOUR BEST FRIEND.
    IF YOU HAVE ANY QUESTIONS PLEASE DON'T HESITATE TO CONTACT ME.
    ANY QUESTIONS, PLEASE EMAIL ME AT TAE254@ANDROIDTABLETS.NET
  4. #3
    9910
    Dec 2010
    Hilo, HI
    Ok i will try to recover, and reupdate and see if that helps. Thanks
  5. #4
    9788
    Dec 2010
    Houston Texas
    102
    Thanked
    8 times
    SYNET7LP
    No problem. Let me know if it helps any.
  6. #5
    9910
    Dec 2010
    Hilo, HI
    I plugged the device in, while powered down, before going to work
    Came home and it was at 100%. Dont have time tonight to play with it but will try to use it with wifi for at least 2 hours in the next two days to test it out. Hopefully its working all right now though... Will update when I know
  7. #6
    9910
    Dec 2010
    Hilo, HI
    I got to use it an hour tonight, browsing the internet, playing some video, and playing angry birds. battery dropped to about 70%. I am very pleased with the device. Once i figure out a way to get rockplayer to play network videos i will be all set. Thank you!
  8. #7
    10594
    Dec 2010
    19
    Thanked
    1 times
    Battery Charging
    Is it safe to say After the update to Power off to allow the battery to charge? i do seem to have short battery life if i unplug the pad to well ill say visit the office. but i only had the pad 2 days. spending a lot of time leaching apks from google searches.
  9. #8
    9910
    Dec 2010
    Hilo, HI
    It seems to me that the battery does charge better when off, or at least much faster. I have installed Pro launch on mine so now it does have a lock screen, but I am pretty sure it doesnt really go to sleep and still uses much more power even if the screen is off.
    Anyway, short answer, I power off when i want to charge.
  10. #9
    Recommendation Second Class 1 year registered 500 Experience Points 1,000 Experience Points 250 Experience Points
    7466
    Nov 2010
    124
    Thanked
    8 times
    Quote Originally Posted by jazzback View Post
    the battery life on a good day with wifi on is going to be about 3 hours max. if you're gaming or heavy downloading etc expect less.
    I have found it charges better and faster with the tablet off.
    I just purchased an inverter for my car and now i don't have to worry about it. If it's low i plug it in while i'm on my way where ever. Only real issue now is having to carry the power brick. I wish i could find a place to buy a couple more of them
  11. #10
    500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class 3 months registered
    10082
    Dec 2010
    Indianapolis
    9
    SYLVANIA SYNET7LP 7" Android OS 2.1
    What/where are you typing to get to the file menu to uninstall phone.apk, bluetooth.apk, etc...
    Have (2) trying to get the battery life to last longer...
Ads:
  1. Perhaps some modifications to sooth your USB charging woes?
    By Childofthehorn in forum Augen Gentouch
    Last Post: 11-26-2011, 10:33 PM
  2. Found a cheap USB charging solution, YMMV
    By Joshua in forum Huawei Ideos S7 Accessories
    Last Post: 11-30-2010, 05:59 AM
  3. Battery Booster – Boost Your Battery’s Running Time
    By Downloadandroid in forum Android Tablet Usage, Tips & Tricks
    Last Post: 11-01-2010, 10:17 PM
  4. Need Help: Apad iRobot isn't charging. Please help
    By crocodile in forum Rockchip RK2808 Tablets
    Last Post: 09-22-2010, 06:29 PM
battery will not charge in elocity 7 tablet
battery will not charge on sylvania netbook
elocity a7 not charging
how do i know android tablet charging
how do you charge a stlvania tablet from a car charger
how to charge a sylvania synet7lp
i have a tablet andd i was playing it and the next day the charger was charging it up i really want to play with it
sylvania netbook battery not charging
sylvania tablet not charging
sylvania tablet will not charge
sylvania tablet wont charge
why is my elocity not charging even if i plug in to the charger
