Register Hello & Welcome to Andriodtablets.net, is this your first visit?
Trying to identify Kernel and possible overclocking possibilities for DM7022 radio
This is a discussion on Trying to identify Kernel and possible overclocking possibilities for DM7022 radio within the Telechips Based forums, part of the More Android Tablets category; Originally Posted by gpmg762 Glad i can help, Mark. I just had the unit installed into my Suzuki Swift Sport today but am not able ...
Page 36 of 54 FirstFirst ... 26 34 35 36 37 38 46 ... LastLast
Results 351 to 360 of 540
Thanks Tree68Thanks
Thread: Trying to identify Kernel and possible overclocking possibilities for DM7022 radio
  1. #351
    Points: 375, Level: 7
    Level completed: 50%, Points required for next Level: 25
    Overall activity: 0%
    Achievements:
    3 months registered 250 Experience Points 31 days registered 100 Experience Points 7 days registered
    81572
    Jan 2012
    Moscow
    34
    Thanked
    9 times
    Points
    375
    Level
    7
    dm7033
    Quote Originally Posted by gpmg762 View Post
    I just had the unit installed into my Suzuki Swift Sport today but am not able to figure out how to connect the steering wheel control.
    Anyone has successfully done it?
    My extension only has four wires (no +5v wire), lead has 5 wires, which is different from the product picture online.
    Anyone manage to get Sygic running on the pad? Copilot works but Sygic hangs after starting.
    Hi. Here is the video, demonstrating steering wheel controls on my Nissan.
    You need to look at the electric circuit diagram of your car and find the type of steering wheel control and wire layout.
    If it uses CAN Bus steering wheel controls, i don`t know if your 777 will work. Propably it won`t.
    If it has a resistive keys - 777 will work. You need to connect GND to GND wire of the steering wheel keys, Steering wheel control has 1 or 2 outputs depending on car model. Connect Ad1 and Ad2 to the outputs. That is all. Now it should work. However, it may recognize not all the keys because they give similar measuring results. In this case you need to add extra 500 Ohm resistor between each AD line and +5V.
    Resistive keys control system is just a set of different resistors. 777 measures resistance (actually - voltage) between GND and ADx and recognizes which key is pressed.
    But anyways, i recommend to download and study service manual for your car first to avoid possible problems.
    There is also one more type of steering wheel controls, but i have no idea how it works and how to connect 777.
    Sygic doesn`t work on my 777.
    gpmg762 thanked this.
    Advertising world
  3. #352
    Points: 641, Level: 12
    Level completed: 82%, Points required for next Level: 9
    Overall activity: 17.0%
    Achievements:
    500 Experience Points 3 months registered 250 Experience Points 31 days registered 100 Experience Points
    83567
    Jan 2012
    South Wales
    120
    Thanked
    10 times
    Points
    641
    Level
    12
    winmark dm7022 / erisin es666 carpad / Samsung Galaxy Note
    Hi gpmg,
    I cant help with the Steering wheel controls (my van dont have them :-( ! ) But I did manage to get sygic maps 10 working sort of, I used the keygen supplied & booted it up, however the first few times I thought it had crashed because it took so long to initalise (over 10 mins !) my pad is the older slower Dm7022 so it might quicker on the the Dm7033, I found it tediously slow and on occasion I got to my destination before it had fired up !!
    Copilot runs much better on my pad, so i've stuck with it but even co pilot dont run as well as it does on my phone.
    Thanks again for your help with youtube.
    Mark
  4. #353
    Achievements:
    83567
    Jan 2012
    South Wales
    120
    Thanked
    10 times
    Points
    641
    Level
    12
    Hi guys,
    I cant believe it ! I just dropped my pad & killed the screen :-(( So, i've got to concentrate on either fixing it or replacing it with dm7033 . I'm truly pissed off at myself & have to keep thinking these things happen (not that its helping much) Any advice hints on either repair or replacement would be very welcome at this stage .
    Mark
  5. #354
    Achievements:
    81572
    Jan 2012
    Moscow
    34
    Thanked
    9 times
    Points
    375
    Level
    7
    dm7033
    Quote Originally Posted by satellitemark View Post
    Hi guys,
    Mark
    Hi mark, sorry to hear about that. But don`t worry. If you need urgent repair, just come to any cellphone/pda/navigation service centre and they should be able to fix your tablet in just a 2-3 hours. It is a very common and easy to fix problem. I am now trying to purchase spare lcd screen assy (LCD+digitizer+face panel) from the manufacturer just to keep one spare screen. I see it is too easy to kill the screen. I should indeed have one as a spare part... Good luck.
  6. #355
    Achievements:
    83567
    Jan 2012
    South Wales
    120
    Thanked
    10 times
    Points
    641
    Level
    12
    Quote Originally Posted by dyn620 View Post
    Thanks for your help & support, I hope the techs here are as good !
    Mark
  7. #356
    Points: 234, Level: 4
    Level completed: 68%, Points required for next Level: 16
    Overall activity: 1.0%
    Achievements:
    3 months registered 31 days registered 100 Experience Points 7 days registered
    88013
    Jan 2012
    Hawthorne, nj
    16
    Thanked
    1 times
    Points
    234
    Level
    Skinning igo?
    I've been trying to skin/play around with Igo settings and I can't seem to figure it out or get it to work. Had anyone had success at changing the skin/look of Igo?
  8. #357
    Points: 273, Level: 5
    Level completed: 46%, Points required for next Level: 27
    Achievements:
    250 Experience Points 3 months registered 100 Experience Points 31 days registered 7 days registered
    88659
    Jan 2012
    Singapore
    10
    Thanked
    2 times
    Points
    273
    Level
    DM7033 TF101 N700
    Hi dyn620,
    thanks for your advice.
    I cannot get any wiring info for my car so I mesure the resistance changes
    with a meter of the 3 remaining wires from original harness and 2 registered.
    Connected AD1 and GND to them directly and managed to get 4 out of 6 buttons working.
    I will try again when I get myself a resistor to connect to 5V and the AD1.
    CC Mark,
    sorry to hear about your mishap, hope you managed to get the lcd fixed.
    Sent from my Transformer TF101 using Tapatalk
  9. #358
    Achievements:
    81572
    Jan 2012
    Moscow
    34
    Thanked
    9 times
    Points
    375
    Level
    7
    dm7033
    Hi, in my car steering wheel controls wiring diagram is like this :
    Trying to identify Kernel and possible overclocking possibilities for DM7022 radio-swcontrols.jpg
    There are 6 buttons in 2 groups. 2 signal lines. Without resistors only 4 buttons work. With resistors - all 6.
  10. #359
    Points: 415, Level: 8
    Level completed: 30%, Points required for next Level: 35
    Overall activity: 10.0%
    Achievements:
    3 months registered 250 Experience Points 100 Experience Points 7 days registered 31 days registered
    58842
    Oct 2011
    Swansea, Wales
    51
    Thanked
    5 times
    Points
    415
    Level
    8
    tablet
    Quote Originally Posted by j8dailo View Post
    Sorry about the delay guys, been busy with my own business lately opening up. The manufacture actually contacted me few days ago so i am assuming they have the files ready but i wasn't online to reply. I tried to get a hold of them again but its chinese new year time and they are closed for 10 days so im out of luck til beginning of next month
    in the meantime, i was able to permenantly root my device and clock it to 720mhz which runs the system fairly decent but still has lag
    Still waiting....love to get 2.3 on this.
    Any further update ?
  11. #360
    Achievements:
    83567
    Jan 2012
    South Wales
    120
    Thanked
    10 times
    Points
    641
    Level
    12
    Hi Guys,
    After a bit of research, I decided to get a DM7033 pad. I've paid £128 for it inc delivery by Fed Ex. I now await its delivery & hoping that I dont get shafted by customs !
    I will report back, when I have it & let everyone know about what I think of the pad compared to the DM7022 as I think I will be the only one who has had direct experiance of both, also if everything works out well I will publish contact details etc (I doubt if I will be the last person to kill their pad )
    No doubt I will need help again setting it up etc & I hope all you guys stick around !
    This thread has been a godsend for me & my first venture into android, so thanks guys !
    Mark
Sponsors:
  1. Replies: 24
    Last Post: 07-21-2011, 12:02 PM
  2. Overclocking
    By ithink2020 in forum Acer Iconia Tab A500 Forum
    Last Post: 04-29-2011, 08:37 PM
  3. GPS possibilities on gTablet
    By rickgg46 in forum Viewsonic gTablet Apps and Games
    Last Post: 04-16-2011, 02:39 PM
  4. Replies: 18
    Last Post: 04-01-2011, 12:49 PM
  5. Overclocking S7?
    By jayghale in forum Huawei Tablets
    Last Post: 02-06-2011, 05:46 PM
dm7022
dm7022 kernel
dm7033
droid bionic overclock
droid bionic overclock kernel
erisin es777a
erisin es777a review
es777a
es777a review
how to overclock droid bionic
overclock toshiba thrive
toshiba thrive overclock
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
