Results 1 to 7 of 7
  1. #1
    Junior Member Achievements:
    24458
    Mar 2011
    Charging problem with Velocity Cruz Tablet
    hi everyone,
    for some reason when charging my cruz the percentage it shows thats done charging goes from 32% to 50%..it will never go higher than 50%. I'm not sure whats up with it. Do I maybe need a new battery? If so, does anyone know where you can purchase an extra one? I saw one on the velocity site, but it's $40 which seems like a lot.
    Ads
  3. #2
    Points: 3,575, Level: 37
    Level completed: 50%, Points required for next Level: 75
    Overall activity: 0%
    Achievements:
    Veteran 1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered
    233
    May 2010
    Montgomery, AL
    89
    Points
    3,575
    Level
    37
    CR48 & VM Cruz Reader
    Is your battery not charging or is it just telling you it's at 50%? In other words, have you tried using it to see how long the battery lasts? It might be just a bug in the charging icon, which you might be able to live with.
  4. #3
    24458
    Mar 2011
    you're right,turns out it's just the charging dock display bc the battery seems to be at full charge. thanks.
    is the 2.0 firmware the latest?
  5. #4
    Ami
    Ami is offline
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 100 Experience Points
    15014
    Jan 2011
    Spokane, Washington
    18
    Velocity Micro Cruz eReader
    Quote Originally Posted by ralcore2007 View Post
    I just have to say that my Cruz tablet (t301) has the same little quirk. I've found that if I restart it right after I pull it from the charger the display will jump from 50% to a fully charged green all the way 100% charged look.
  6. #5
    Ami
    Ami is offline
    15014
    Jan 2011
    Spokane, Washington
    18
    the T301 supports 2.2 firmware upgradable via the Cruz website.
  7. #6
    32685
    May 2011
    14
    For R101 2.0 would be the highest as of now.
    Try a freeware battery app, like battery snap, or battery booster, they give good statistics along with a usage chart.
    Glad yours is working!
  8. #7
    104871
    Apr 2012
    New Orleans
    velocity micro cruz
    well, my tablet is not holding a charge but to tell you the truth i don't even know what the green light means...
    also i have to turn it off and plug the charger in to see the green light....any advice on what it can be?
Ads:
  1. Velocity Cruz tablet
    By stevenjwilliams83 in forum Velocity Micro Tablets
    Last Post: 09-06-2012, 09:23 AM
  2. Velocity Micro Cruz Reader WIFI Problem
    By dmotorcade in forum Velocity Micro Tablets
    Last Post: 08-01-2012, 05:28 PM
  3. Velocity Cruz Tablet
    By garyg007 in forum Velocity Micro Tablets
    Last Post: 01-14-2012, 08:34 AM
  4. Velocity Cruz Reader Tablet
    By divine300 in forum Velocity Micro Tablets
    Last Post: 12-15-2011, 07:49 PM
cruz ps47 tablet charger port moved
cruz tablet charge fully
cruz tablet charger
cruz tablet charger look like
cruz tablet not charging
cruz tablet will not charge when on
cruz wont charge
does anyone else have problems with the velocity cruz chargers
how to get your cruz reader tablet to.charge
my cruz tablet wont charge
my velocity cruz tablet wont charge
velocity cruz tablet not charging
