Results 1 to 4 of 4
  1. #1
    Junior Member Achievements:
    7485
    Nov 2010
    Exclamation Cruz Reader Help!!! Wont Boot
    I need some serious help!
    I turned my cruz reader off then when I turned it back on it showed "Pandigital Novel" instead of Cruz! After that I tried restoring to Normal Firmware to fix it and then It got into a never ending boot loop.....
    Then I tried restoring again but then it got stuck in a restore loop and then shut off suddenly and now It wont turn on...................
    HELP PLEASE!!!!!
    Ads
  3. #2
    10558
    Dec 2010
    Florida
    Cruz Reader
    Support Center check out the troubleshooter
    What should I do if my Cruz device will not turn on?
    If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
    • Locate the Cruz RESET location between the Power Button and mini-USB port.
    • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
    • Turn on your Cruz
    If the steps above do not allow you to power on again, then continue with the steps below:
    • Remove the Cruz from the charger and eject the External SD card.
    • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
    • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
    • Return the back cover to your Cruz and snap it into place.
    • Re-insert your External SD card and power on your Cruz.
  4. #3
    7485
    Nov 2010
    Sorry for the late reply! Neither of those worked!
  5. #4
    66848
    Dec 2011
    Sugar Land, Tx
    Acer a100, acer a500, droid phone
    Thanks - it cleared up my problem.
Ads:
  1. Adroid Wont Boot ?? helpp !!
    By harryh in forum Android Tablet Q&A
    Last Post: 09-13-2011, 05:01 AM
  2. Huawei S7 / Cruz e-Reader / Cruz Tablet comparison
    By pbrauer in forum Huawei Ideos S7
    Last Post: 01-20-2011, 07:18 PM
  3. Cruz Reader Test
    By charles in forum Velocity Micro Tablets
    Last Post: 12-30-2010, 04:40 PM
  4. Cruz Reader
    By LegnasRoge in forum Velocity Micro Tablets
    Last Post: 12-27-2010, 10:31 PM
  5. my apad wont boot anymore what shall i do?
    By Annalise.Cassar in forum Rockchip RK2808 Tablets
    Last Post: 11-14-2010, 12:06 PM
cruz reader help
cruz tablet eon't boot up
cruz tablet not turning on
cruz tablet will not come on
cruz tablet will not turn on
cruz tablet wont turn on
megafeis m970 tablet will not turn on
my cruz reader won't turn on
my cruz tablet will not turn on
my cruz tablet wont turn on
t3o1 wont turn on
velocity cruz tablet wont turn on
