Register Hello & Welcome to Andriodtablets.net, is this your first visit?
[Howto] Install CWM, Custom ROM, Flash Player, and Market Fix for 1.1 based ROMs
This is a discussion on [Howto] Install CWM, Custom ROM, Flash Player, and Market Fix for 1.1 based ROMs within the Viewsonic gTablet Technical forums, part of the Viewsonic gTablet category; Originally Posted by RumbleKittie Argh. I'm so frustrated with myself. I'm trying to install a 1.2 Dev branch ROM coming from CM7. In the process, ...
Page 18 of 18 FirstFirst ... 8 16 17 18
Results 171 to 174 of 174
Thanks Tree16Thanks
Thread: [Howto] Install CWM, Custom ROM, Flash Player, and Market Fix for 1.1 based ROMs
  1. #171
    Moderator
    Points: 10,658, Level: 68
    Level completed: 52%, Points required for next Level: 192
    Overall activity: 0%
    Achievements:
    10000 Experience Points 1 year registered 5000 Experience Points 500 Experience Points 1000 Experience Points
    17052
    Feb 2011
    Kinshasa, Democratic Republic of the Congo
    728
    Thanked
    95 times
    Points
    10,658
    Level
    68
    Droid 2, Nookcolor, Viewsonic G-Tablet
    Quote Originally Posted by RumbleKittie View Post
    I'm trying to install a 1.2 Dev branch ROM coming from CM7. In the process, I managed to softbrick the device, so I used these NVFlash directions ([RECOVERY] nvflash FULL restore, using either 1.1 or 1.2 based images - [G-TABLET] - SlateDroid.com) to restore stock 4349.
    Next, I tried installing CWM, and that's where I'm having the greatest trouble. I downloaded the internal version of CWM from this thread: http://www.androidtablets.net/forum/...-g-tablet.html. I power off and reboot into recover using power and Vol +. Instead of going into CWM, I went into 'Android system recovery <3e>' and at the bottom, I get the following message:
    E:Can't mount /dev/block/mmcblk2
    (no such file or directory)
    E:Can't mount SDCARD2:recovery/command
    Finding update package...
    Opening update package...
    Installing update...
    And then it just gets stuck there. Anyone else encounter this? I tried installing CWM from internal memory and from microSD card and it doesn't seem to work. I've flashed other ROM's before, I'm not sure why I'm having such trouble tonight. :-( I appreciate any help or insight.
    Thanks!
    This thread is for 1.1 ROMs only.
    Fugatech
    nookcolor 1.1 rooted with Auto-Nooter 3.0.0//Viewsonic G-Tab running 1.1 Bottle of Smoke a5.2 Honeycomb //Droid 2 rooted running Liberty v1.5
    Remember to use the Thanks button!
    Advertising world
  3. #172
    Points: 343, Level: 6
    Level completed: 86%, Points required for next Level: 7
    Overall activity: 0.5%
    Achievements:
    7 days registered 31 days registered 100 Experience Points 3 months registered 250 Experience Points
    33672
    Jun 2011
    16
    Points
    343
    Level
    Quote Originally Posted by Fuganater View Post
    Oops, sorry!
  4. #173
    Points: 603, Level: 12
    Level completed: 6%, Points required for next Level: 47
    Achievements:
    3 months registered 250 Experience Points 500 Experience Points 100 Experience Points 31 days registered
    46701
    Aug 2011
    Points
    603
    Level
    12
    I tried doing the Market fix 1 but I don't even have a Market app in my system applications. What am I missing?
  5. #174
    Points: 68, Level: 1
    Level completed: 36%, Points required for next Level: 32
    Overall activity: 0.2%
    Achievements:
    52705
    Sep 2011
    Points
    68
    Level
    Hi guys,
    I tried to Install tnt 4.3 lite the thing started installing then got the android screen that kept reloading
    Tried to go to recovery. I'm getting Recovery key detected in the upper left corner with the birds pic and it is frozen.
    Then tried to install cwm the "external sd version" have the update.zip and the recovery on the root of the microsd and still nothing is happening its not installing cwm "still stuck on the recovery key detected with the birds"
    Any ideas? Am I missing on something?? can i use the internal memory cwm somehow or maybe format the internal mem?
Sponsors:
  1. Replies: 607
    Last Post: 02-09-2012, 08:42 AM
  2. Which ClockworkMod image to install for M701 ?
    By sufehmi in forum Telechips TCC8902 Tablets
    Last Post: 11-29-2011, 02:12 PM
  3. Replies: 14
    Last Post: 02-09-2011, 08:03 PM
  4. How to install Adobe Flash Player on Archos Tablets ????
    By movadoevo8 in forum Archos Tablets
    Last Post: 01-08-2011, 11:16 AM
  5. Replies: 3
    Last Post: 12-29-2010, 05:43 PM
clockworkmod 0.8
clockworkmod download
clockworkmod v08
clockworkmod v08 download
clockworkmod zip download
cwm 0.8 download
cwm android market
cwm download
cwmod internal.zip
cwmod microsd.zip
download clockworkmod v08
g tablet market.zip
Tags for this Thread
Copyright © 2012 vBulletin Solutions, Inc. All rights reserved.
