Results 1 to 6 of 6
  1. #1
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points Tagger Second Class
    1648
    Aug 2010
    13
    HOW TO FIX : Tablet will not turn on or boot after splash
    Original Post on another forum:
    Hey guys,
    After having no issue for the last month or so using CWM, tonight I booted into CWM as normal and then screen went blank.
    I mean really blank, can't turn it off or on. Would a simple unplug of the battery and replug do the job or do I need to break out the JTAG setup? If JTAG is needed, does anyone know where that is on the board?
    I did recently NVFlash from 1.1 to 1.2 so any advice on how to get this running again is invaluable as this tablet has info on it that I need to pull off. The only thing I can think of is if something in the recovery file got trashed and when it booted, it killed it.
    Thanks in advance.
    HOW TO:
    Open up the Gtablet using an iPod pry tool or flat screwdriver. Start at a corner and work your way through.
    Locate the area in Red.
    Now Unplug the battery, left speaker, and capacitive touch cables. Then go through and use a piece of copper braid on your finger or a grounding pad and ground out those connectors as well as surrounding capacitors. *THIS IS A CRITICAL STEP*
    Before putting the back on the tablet, throw the Tablet into AVX mode by pressing power and volume down. This will be the first test as to whether or not it worked.
    Yays! We did it and did not have to break out the BusPirate to do JTAG!
    Ads
  3. #2
    7 days registered 31 days registered 100 Experience Points 100 Experience Points
    35733
    Jun 2011
    North Carolina
    Viewsonic gTablet
    Ok... I've pried open my case but I have a question. What exactly do you mean by "grounding out the connectors"? I know this may be a newbie question but since I have already bricked my tablet this is probably my only alternative. I'd appreciate any assistance you can give.
  4. #3
    Moderator Achievements:
    10000 Experience Points 1 year registered 5000 Experience Points 500 Experience Points 1000 Experience Points
    17052
    Feb 2011
    728
    Thanked
    95 times
    Be careful doing this....
    Fugatech
    nookcolor 1.1 rooted with Auto-Nooter 3.0.0//Viewsonic G-Tab running 1.1 Bottle of Smoke a5.2 Honeycomb //Droid 2 rooted running Liberty v1.5
    Remember to use the Thanks button!
  5. #4
    Administrator Achievements:
    50000 Experience Points 25000 Experience Points 10000 Experience Points 5000 Experience Points 1000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    549 times
    I have said this other places....but while I will leave this posting up I am going to say that NO ONE should be doing this. The odds of this being the only fix to your problem are slim to none, and the odds of BORKING your tablet so it never works right again are high.
    If for some reason you really really really think this is the only way to go, find a place in your area that does smartphone repair, print out these instructions, and take it there. For about $20 you can have a professional do it and you may actually wind up with a tablet that still works.
    I have been using these tablets since the first one hit the market in July 2010, and have never ever HAD to open one up, and this includes after having done some pretty awful things to my tabs.
    Just my opinion and two cents worth....
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
  6. #5
    35733
    Jun 2011
    North Carolina
    Viewsonic gTablet
    Thanks for the advice. I'll contact a smartphone engineer first and see if she can perform the steps listed above.
  7. #6
    114253
    May 2012
    kosovo
    viewpad 10
    In viewsonic vpad 10 how to repair like thiss,any solution ?
Ads:
  1. [APK;Game] Icy Splash
    By Angel_ik in forum Android Tablet Games
    Last Post: 12-21-2011, 01:32 AM
  2. Android 2.2 - Will not boot/Turn on
    By soulmusiq in forum Freescale Based
    Last Post: 09-02-2011, 04:55 PM
  3. Wi-Fi Doesn't' Turn On After Re-Boot (CM7 RC4)
    By gbeardmore in forum Nook Color Technical
    Last Post: 04-07-2011, 07:01 PM
  4. Changing boot animation and boot splash images(?).
    By TRGX in forum Gome Flytouch II
    Last Post: 01-23-2011, 10:11 PM
  5. How do I change boot splash?
    By arachnophile in forum Android Tablet Hacking
    Last Post: 12-15-2010, 04:55 PM
acer tablet will not turn on
acer tablet wont turn on
android tablet will not turn on
android tablet wont turn on
asus tablet wont turn on
how to fix a tablet
how to fix a tablet that wont turn on
how to fix android tablet
how to fix tablet
how to fix tablets
viewsonic g tablet repair
viewsonic g tablet wont turn on
Tags for this Thread
