Results 1 to 9 of 9
  1. #1
    Junior Member Achievements:
    7 days registered
    44098
    Aug 2011
    ny
    g tablet
    G Tablet Recovery Mode Help!
    I have a similar issue. I have TnT Lite on my tablet now and it is working fine with now issues. I want to install the new honeycomb os on my tablet but I can not get into recovery mode.
    I get the "Recovery Key Detected" in the upper left corner of the screen while the VS Birds logo is on the screen then it got to the next screen w/ gtablet logo, then a black screen loads with a box and status bar, then NOTHING it resets.
    Any ideas?
    Ads
    Advertising world
  3. #2
    Administrator Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    have you properly installed clockwork? you may need to do the CWM.08 install again
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
  4. #3
    Senior Member Achievements:
    5,000 Experience Points 1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    Archos 101, Viewsonic G-Tablet, Motorola Droid X.... test drove: Augen gentouch 78, Coby Kyros 7015
    It sounds like you have the stock recovery on your tablet and it's picking up that you have a command file in the Recovery folder and an update.zip on the SD partition.. when you do the recovery button and as soon as the box and bar comes up hit the home button once this should allow you to see what commands the recovery is going through...
    Best thing to do, I'd say, is delete the update.zip file that is on your sd card.. and delete the file that is in the Recovery folder using a file manager... then i'd look to puting Clockwork back on it using the method posted in the stickies... then flash away which ever rom you like that'll work for your bootloader version... but with having what sounds like bootloader 1.1 on the tablet i'd suggest Gtabcomb it's to beta3.3... there are seperate versions for bootloader 1.1 and 1.2.. You can find it in the gtab development section on XDA.. I have it installed right now and haven't had any issues other than the facebok app not playing well... though i think there is a fix for it i just haven't taken time to research it... [ROM][BL1.1][BL1.2] GtabComb beta 3.3 (updated 7/27/2011) Gtablet\Zpad T2 - xda-developers
    hope this helps
  5. #4
    7 days registered
    44098
    Aug 2011
    ny
    g tablet
    I hit the HOME button and here is what I got (only appeared for a sec but got most of what I could)
    "no such file directory
    cannot mount sdc2 recovery/command"
  6. #5
    7 days registered
    44098
    Aug 2011
    ny
    g tablet
    How do I find out what bootloader is on my system? I have a lock screen so do i have 1.2?
  7. #6
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    What ROM are you on? We can tell you from there.
    Sent from my Xoom using Android Tablet Forum
  8. #7
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    The way MOST of the roms for this tablet work are on the premiss that there is an sdcard mem partition that is on the tablet's internal storage that is called the "sdcard" and the external sd referred is to as "SDcard2". There are a few exception though, We can discuss those later if need be.
    In my opinion from the info given at hand you have attempted to load clockwork from the wrong mem partition.. you need to delete the Recovery folder and the Update.zip from the internal storage, "sdcard"
    Once you've deleted the recovery folder/command file, you can try to reboot into recovery to make sure which bootloader you have... if you have 1.1 the tablet will do the message "recovery button detected" then continue to boot on through to your current rom because there isn't a command file to tell it what to do.... If you have 1.2, when you do the recovery button you'll get the same message but it'll boot on through to a text based recovery managment utility that has blue lettering... from here u can just choose to reboot by scrolling up and down with the vol keys and selecting with the home button.... once you know which bootloader version you have procedeed with install of the proper version of clockwork... if you're on BL1.1 and are gonna use the internal mem partition ,"sdcard", use the version labled "(internal)" on Fuganator's posting.. if you have and external sdcard, "sdcard2", and want to use it use the one labeled "(sdcard)"....
    I can't really offer any advice on dealing with BL1.2 and getting Clockwork on it, as i haven't had need to update to it as of yet, but there are posts here and on XDA concerning the matter
  9. #8
    7 days registered
    44098
    Aug 2011
    ny
    g tablet
    I figured it out!! THANK YOU FOR ALL THE HELP!!! I download the 'internal' clockwork mod and that worked. I never had an option to download external vs internal before. couldn't have done it with out your help! I'm running Honeycomb without any issues so far!
  10. #9
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    Glad to help...
Ads:
  1. recovery mode
    By meijel in forum Gome Flytouch II
    Last Post: 10-30-2011, 09:39 PM
  2. Unable to get into recovery mode on G-Tablet
    By OldDogEyes in forum Viewsonic gTablet
    Last Post: 10-02-2011, 10:28 PM
  3. install firmware without recovery mode
    By ksporry in forum Freescale Based
    Last Post: 09-16-2011, 11:15 PM
  4. How to put X5a tablet with G-sensor into recovery mode?
    By michellynn in forum Coby Generation 1
    Last Post: 01-12-2011, 07:51 PM
ct0712 firmware
ct0712 recovery
ctab ct0712
ctab ct0712 firmware
desbloquear tablet ctab ct0712
firmware ctab ct0712
hkc tablet recovery mode
recovery mode for g-tab
resetear tablet ctab ct0712
tablet ctab ct0712
viewsonic g tablet safe mode
viewsonic gtablet safe mode
