Results 1 to 9 of 9
  1. #1
    Member Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    45763
    Aug 2011
    USA-Florida
    67
    Thanked
    4 times
    IdeaTab A2109
    Question Safely Remove USB Thumb Drive
    Hello All,
    I use a Viewsonic gTablet, I already know that the android os is sure different than the ms windows os system I'm used to. With windows..when you plug in a usb 2.0 thumb drive, windows automatically recognizes it, and when you are finished using it, you just 'eject' it and then you can safely remove it. Is there ANY way to do this when using a android tablet ?
    Thanks,
    David
    Ads
    Advertising world
  3. #2
    Junior Member Achievements:
    31708
    May 2011
    texas
    12
    Thanked
    1 times
    Viewsonic G-Tablet
    It depends on what rom you are using. But in general you would go to whatever File Explorer you have on your tab, and look for USB Storage. It will show you what's on the drive and to remove it there might be a unmount link in the File Explorer. On Gtabcomb rom on the bottom where the task bar is you touch where the time is and it gives you a list of what is opened. If you close the X next to usb storage it "ejects" the drive. On the default os, I couldn't tell you.
  4. #3
    Senior Member Achievements:
    1 year registered Recommendation Second Class 500 Experience Points 1,000 Experience Points 250 Experience Points
    38506
    Jul 2011
    florida
    337
    Thanked
    9 times
    super
    Quote Originally Posted by luvduchovny View Post
    It should be in settings=>storage=>unmount USB storage
    sent from my Century Eyes Gtablet using Tapatalk
    If I'm not poking around on this forum, you can find me HERE.
  5. #4
    Points: 4,188, Level: 41
    Level completed: 19%, Points required for next Level: 162
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    26811
    Apr 2011
    198
    Thanked
    20 times
    Points
    4,188
    Level
    41
    Google Nexus 10/Google Galaxy Nexus
    But I'm curious - is there really a need for it on an Android tablet? I never really even thought to consider it.
    Awaiting the Transformer Prime.
  6. #5
    5,000 Experience Points 1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    Archos 101, Viewsonic G-Tablet, Motorola Droid X.... test drove: Augen gentouch 78, Coby Kyros 7015
    The Main reason you want to want to "reject" or "unmount" USB peripherials is to stop electrical current flowing to them.. if you just pull it and current is still going via a file transfer or being read it can, I emphasise can, not necessarily will but might and can, do damage to the usb device or the system circuit board or corrupt the data on the device in the instance of a flash drive... typically though if you wait and make sure the device isn't in use at the time of pulling it it "shouldn't" do harm. IMO ...Better safe than sorry though... it's better device practice to unmount the device before removing it.
  7. #6
    38506
    Jul 2011
    florida
    337
    Thanked
    9 times
    super
    Quote Originally Posted by Swould333 View Post
    +1 with that. I thought that Windoze only did that, until I smoked an old beater 512M that I've had for 8 years. Can't read it at all, completely unresponsive.
    sent from my Brilliant Corners with Clemsyn Kernal Gtablet using Tapatalk
  8. #7
    Achievements:
    26811
    Apr 2011
    198
    Thanked
    20 times
    Points
    4,188
    Level
    41
    I wonder if this also occurs with USB-powered HDDs. Different tech - uses power to spin plates, and since the electricity is translated into mechanical force (mostly),a stiffen cut-out shouldn't have any effect.
  9. #8
    1474
    Aug 2010
    North Carolina
    354
    Thanked
    23 times
    Quote Originally Posted by Walkop View Post
    With this, again, it's weather or not the device is reading or writing to the drive... just a cut out of power to spin the plattens shouldn't be an issue i wouldn't believe... But you should unmount one of these drives in the storage section of settings just as you would any other flash storage device if it recognizes it as a storage medium.
  10. #9
    45763
    Aug 2011
    USA-Florida
    67
    Thanked
    4 times
    IdeaTab A2109
    Hello,
    At least with the brilliant corners rom I installed yesterday, there's an application in there called 'sniffer'..it allows you to 'unmount' drives. Glad to see it available.
    David
Ads:
  1. Safely removing from computer
    By mtwd in forum Samsung Galaxy Note/Tab
    Last Post: 05-26-2011, 01:41 AM
  2. How do I safely remove my USB flash drive
    By Johnny Mac in forum WonderMedia Based
    Last Post: 04-23-2011, 11:10 PM
  3. How do I safely remove my USB flash drive
    By Johnny Mac in forum Gome Flytouch
    Last Post: 04-23-2011, 11:36 AM
  4. How do you de-mount a USB thumb drive?????
    By willber in forum Coby Tablet Accessories
    Last Post: 02-24-2011, 05:41 PM
  5. Replies: 0
    Last Post: 01-03-2011, 04:44 AM
android remove usb storage
android safely remove usb
eject usb android
how to eject flash drive from android tablet
how to eject usb from android
how to eject usb from android tablet
how to remove flash drive from android tablet
how to safely remove usb device from android tablet
how to safely remove usb drive from android tablet
how to safely remove usb from android tablet
how to safely remove usb from tablet
