Results 1 to 6 of 6
Thanks Tree3Thanks
  • 1 Post By soltner59
  • 1 Post By pbrauer
  • 1 Post By WeekendsR2Short
Thread: Touch-screen needs more than a touch - HELP!
  1. #1
    66996
    Dec 2011
    Huntington Woods, Michigan, USA
    Viewsonic g-tablet
    This forum is great. I've read many of posts that other users have written and have learned so much from them. I purchased the ViewSonic G-Tablet and love it with one exception......
    The response of the touch screen is horrible. My fingers are sore from having to "touch" the screen. Has anyone else experienced the same issue? Has anyone come up with a solution?
    I have followed pbrauer's excellent sticky on installing ClockWorkMod v08, and am using TnT G-Harmony v1.2.
    I really love the tablet, but can't seem to solve this issue. Any help will be much appreciated.
    Ads
    Advertising world
  3. #2
    Points: 2,568, Level: 30
    Level completed: 79%, Points required for next Level: 32
    Overall activity: 0%
    Achievements:
    1,000 Experience Points 1 year registered 500 Experience Points 250 Experience Points 100 Experience Points
    27637
    Apr 2011
    Katy, TX, USA
    37
    Thanked
    2 times
    Points
    2,568
    Level
    30
    Velocity Cruz, Viewsonic Gtablet
    There is a "touchrecalibrate.apk" you can download, Google it to find the download.
    jmdwan thanked this.
  4. #3
    Administrator Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    Do you have a screen protector on the tablet? Since it is a capacitive screen, pressure actually has nothing to do with the responsivity of the screen.
    If you have dry skin that can impact it, as an experimient, try with lotion on you hands. Also, do NOT use your nails, as this will not work reliably. You need to use the pads of your fingertips.
    Sent from my ADR6400L using Android Tablet Forum
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
  5. #4
    66996
    Dec 2011
    Viewsonic g-tablet
    Downloaded the "touchrecalibrate.apk" (thank you GoJimi) file and ran it on the g-tablet. No change in the "touch" of the screen. Also tried some hand lotion - still no luck with the touch..... I've read some other forums that mention the digitizer - any tests that I can run on the digitizer?
    Thanks to soltner59 and pbrauer for the quick responses!
  6. #5
    66996
    Dec 2011
    Viewsonic g-tablet
    Sorry - I didn't answer pbrauer's question fully... I do not have a screen protector on the g-tablet.
  7. #6
    Junior Member Achievements:
    7 days registered 31 days registered 3 months registered 100 Experience Points 250 Experience Points
    72399
    Dec 2011
    Cleveland, Tn
    Thanked
    1 times
    Viewsonic GTablet, HTC MT4Gs
    There is an internal process that you can perform that will force it to recalibrate itself. You will need Root Explorer of File Expert to access your core files as well as your SD card. Create an EMPTY file called calibrate.ini and copy it to the the root directory of the android system as well as your SD card and reboot. During this process leave it still and laying flat on the tabletop. You can check after your reboot for the change in sensitivity. If it hasn't changed enough to suit you, simply repeat the process until it has gotten to the point you like it and go back in and erase the calibrate.ini files you created and you should be good to go.
Ads:
  1. Touch screen
    By yandizt in forum Android Tablet Q&A
    Last Post: 11-25-2011, 09:40 PM
  2. touch screen does not respond to touch
    By mrselwyn in forum Android Tablet Q&A
    Last Post: 11-14-2011, 05:12 PM
  3. Touch screen
    By luck008 in forum Coby Tablets
    Last Post: 07-13-2011, 06:37 PM
  4. S7 touch screen
    By 1kyle01 in forum Huawei Ideos S7 Technical
    Last Post: 04-26-2011, 06:44 AM
adjust sensitivity of kindle fire hd
calibrate kindle fire screen
calibrate.ini
calibration.ini
does kindle fire hd have touch screen calibration
how to change sensitivity on kindle fire
kindle fire screen calibration
kindle fire touch screen calibration
touch sensitivity calibration apk download
touchrecalibrate apk download
touchrecalibrate.apk download
viewsonic g tablet touch sensitivity
