Results 1 to 4 of 4
  1. #1
    73702
    Dec 2011
    Southern California
    Viewsonic G tablet
    Cool Can't connect to wifi
    Bought my wife a Viewsonic gtablet for Christmas. The first one for us. I cannot get it to connect to wifi. It sees my home wifi and goes to connect then says connection is remembered but doesn't do anything. I would really appreciate any help anyone can provide. Also, is anyone in the So-Cal area? Thank you very much.
    Baggerjohn
    Ads
    Advertising world
  3. #2
    78807
    Dec 2011
    Viewsonic G Tablet
    Make sure your battery is at least 50%. When I bought mine, the battery was dead but I plugged it in using the charging adapter and tried to set up the wireless. Had the same problem you mentioned. Once I let it sit for an hour or so and get to around 55% - 60%, the wireless set up worked fine.
  4. #3
    78886
    Dec 2011
    wm8650 android tablet
    Mine did that so i just turned off the wifi on the tablet n then turned it back on. Then i click my wifi connection n clicked connect
  5. #4
    Administrator Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    4111
    Sep 2010
    Edina, MN USA
    3,651
    Thanked
    556 times
    +1 for this being an error in the network config. Go to settings->wireless and network, and then press and hold on the entry for your existing network. You can either chose Forget and then rescan, or Modify and see if you can find the error there.
    Peter B. - email: tardis@androidtablets.net | Twitter: pbbrauer | Google+: pbbrauer | gTalk: pbbrauer@gmail.com
    Current Devices, ROMs:
    (Active) VZW Samsung Galaxy Nexus- Rooted, Android ICS 4.0.2 | ASUS Transformer Prime TF201- Rooted, Unlocked, Virtuous Prime-9.4.2.15 v1 ROM
    (Retired) Viewsonic gTab - Rooted, Flashback 10.3 (Honeycomb) | Huawei S7 - Rooted, Froyo Fusion R2 | (Other) Nook Color (2 of these) | Gentouch 7/8 - Rooted, Lincrackers Pirate 3
    Remember to "Thank" people that help you out! |Click here for general Questions?
Ads:
  1. Can't connect to WiFi?
    By andersen1127 in forum Acer Iconia Tab A500 Forum
    Last Post: 12-09-2011, 05:54 PM
  2. I cant connect to wifi :(
    By Chelle13 in forum Android Tablet Discussions
    Last Post: 12-06-2011, 09:19 AM
  3. cant connect to wifi
    By viccy in forum Android Tablet Q&A
    Last Post: 11-02-2011, 09:13 PM
  4. Help Won't Connect to Wifi
    By Reverb in forum Gome Flytouch II Variant 2
    Last Post: 04-07-2011, 01:01 PM
  5. Can't connect to wifi
    By The Don in forum Huawei Ideos S7
    Last Post: 02-01-2011, 09:31 PM
Android Tablet won't connect to wifi
android tablet won't connect to home wifi
connect fusion tablet to wifi
g tablet wont connect to wifi
google android tablet doesnt connect to my wifi
torque tablet cannot connect to wifi
torque tablet cant connect to wifi
torque tablet cant connect with wifi
torque tablet wifi problem
viewsonic g tablet will not connect to wifi
viewsonic tablet wifi problem
why my android tablet doesnt connect to wifi
