Results 1 to 7 of 7
  1. #1
    Junior Member Achievements:
    25762
    Apr 2011
    Utah
    Viewsonic gTablet
    Question Micro SD Card Won't Stay In
    I can't get the micro SD card to stay in my new woot gTablet--it just springs back out when I push it in. How do I get it to lock in or catch inside the tablet? I called support and they verified that it should stay in, and Woot sent me a replacement, but this one does the same thing! What's the trick???
    And if I hold it in with my finger, the gTablet recognizes it and it works great.
    Ads
    Advertising world
  3. #2
    25145
    Apr 2011
    NH
    10
    10.1" Generic Apad
    too bad I couldn't cross breed it with my tablet. I can't get mine OUT !
  4. #3
    Moderator Achievements:
    10,000 Experience Points 1 year registered 5,000 Experience Points 500 Experience Points 1,000 Experience Points
    17052
    Feb 2011
    728
    Thanked
    95 times
    Are you putting it in the right way? And pressing just a bit more into where it is flush? It should be flush once inserted.
    Fugatech
    nookcolor 1.1 rooted with Auto-Nooter 3.0.0//Viewsonic G-Tab running 1.1 Bottle of Smoke a5.2 Honeycomb //Droid 2 rooted running Liberty v1.5
    Remember to use the Thanks button!
  5. #4
    26176
    Apr 2011
    I have the exact same problem with mine, my tablet recognizes the MicroSD card but it doesn't stay in unless I hold it. DId you manage to solve your problem?
  6. #5
    25762
    Apr 2011
    Utah
    Viewsonic gTablet
    Unhappy
    I haven't found a solution yet! Very disappointed in Viewsonic and Woot so far. I'd really like to start modding it, but don't want to spend any time on something that I may not end up keeping if I don't get this resolved.
  7. #6
    25762
    Apr 2011
    Utah
    Viewsonic gTablet
    Resolved!!
    OK, got it. I gave up on getting help specific to the gTablet, browsed support for other devices with micro SD card problems, and found that they overwhelmingly were resolved by finding something to push them in a little bit deeper at just the right angle, and that worked on both of my gTablets (the original and replacement). I'll be keeping the original and sending the replacement back. And WHY didn't Viewsonic support know how ridiculously anal the slot is???
  8. #7
    Points: 42, Level: 1
    Level completed: 84%, Points required for next Level: 8
    Overall activity: 1.0%
    Achievements:
    7 days registered
    192176
    Mar 2014
    United States
    Points
    42
    Level
    This Worked for Me, Too!
    Quote Originally Posted by dolthead View Post
    I used the tip of a letter opener to gently push the card in just a bit further than I could with just my finger and it worked. All set now.
Ads:
  1. Anyone Having Problems with micro SD Card?
    By voyageurs60 in forum Viewsonic gTablet
    Last Post: 05-12-2011, 09:07 PM
  2. How to read TF or Micro SD card with your tablet?
    By exnoiuh in forum Android Tablet Discussions
    Last Post: 04-24-2011, 12:47 PM
  3. Micro SD card - What size do I need for rooting?
    By Bootstrap Bill in forum Nook Color Technical
    Last Post: 04-08-2011, 12:59 PM
  4. Moving files from USB external card reader to Galaxy's micro SD card
    By fred615 in forum Samsung Galaxy Note/Tab
    Last Post: 02-21-2011, 03:52 PM
  5. A81E problem with Micro SD card
    By spidermite in forum Witstech Tablets
    Last Post: 01-16-2011, 11:00 AM
cant get sim card to stay in ellipsis 7
lg p920 external sd card won't stay in slot
micro sd card not staying in
micro sd will not stay in samsung tab 3
my sd card wont stay in my phone
sd card doesn't stay in galaxy s
sd card will not stay in slot
sd card won't stay in phone
sd card wont stay in galaxy exhibit
surface tablet sd card not staying inserted
why wont my sd stay card in my tablet
Tags for this Thread
