Results 1 to 4 of 4
  1. #1
    97378
    Mar 2012
    G Tablet will not turn on and is not responsive
    My G tablet Model NO. UPC300-2.2 (with honeycomb) has been working for a little over a year, but just yesterday the battery fully died for the first time while i was using it. I went to plug it in and let it charge (the red light comes on and turns green, but when i unplug it and plug it back in again it turns red immediately) and i tried to power it up. The device is unresponsive and will not turn on in any mode. I have tried a hard reset with the internal reset button on the back. Also, i tried to put it into APX mode, but it won't do anything. No physical keys work to turn it on or even gain a response. I just sits there with a black powered off screen. Please help!
    Ads
  3. #2
    103713
    Mar 2012
    usa
    viewsonic, hp touchpad
    well i have same problem... take the hole filler out ot the back.. need take screw out.... open the back of the tablet then un hook the battery.. then put it back together .. after you done reassemble it turn it on... my did turn on perfectly so try it
  4. #3
    Senior Member Achievements:
    25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 3 months registered 1,000 Experience Points
    100550
    Mar 2012
    Shenzhen, China
    389
    Thanked
    28 times
    Bad news, may seek help from the seller ?
  5. #4
    103713
    Mar 2012
    usa
    Quote Originally Posted by Androidinabox.com View Post
    well sometime is not that easy since we buying second hand tablet.. or we root the talbet it void warranty anyway.. but he has the same problem as i do just yesterday.. i charge my tablet then it wont turn on anymore i am mad.. so i recall that some where people say it lock up ... all you need to do is open it up and then pull the battery connnector for few second then hook it back.. becareful..it not that hard but dont break anything... enjoy
Ads:
  1. Help My 7127 screen is not responsive!
    By nklemens in forum Coby Generation 2
    Last Post: 05-09-2012, 03:46 PM
  2. Touchscreen is non-responsive
    By dharlow in forum Witstech Tablets
    Last Post: 04-20-2011, 10:37 AM
  3. Touchscreen less responsive after reboot
    By jinnijinn in forum Nook
    Last Post: 02-16-2011, 04:08 PM
  4. Is your touch screen responsive?
    By anduser in forum Android Tablet Discussions
    Last Post: 11-12-2010, 02:37 PM
  5. Gentouch screen not responsive?
    By jasonh in forum Augen Gentouch
    Last Post: 09-19-2010, 12:04 AM
g tablet not charging
g tablet not turning on
g tablet wont turn on
mapan tablet won't turn on
my gtablet ipad wont turn on
viewsonic g tablet not turning on
viewsonic g tablet will not turn on
viewsonic g tablet wont charge
viewsonic g tablet wont turn on
viewsonic gtab charges but does not turn on
viewsonic gtablet upc300-2.2 hard reset
viewsonic upc300-2.2 hard reset
