Results 1 to 8 of 8
  1. #1
    Junior Member Achievements:
    50088
    Sep 2011
    New Jersey
    VTAB 1008
    Battery Life and Warm Tablet
    Hello everyone, i just wanted to see what everyone is getting for battery life. Right now I get around 5 hrs of life just reading and web surfing. It also seems to take a long time to fully charge the unit. I hook up the charger and it takes over 8 hrs for the green light to come on to signal full charge.
    My unit also gets very warm when in use. The lower back gets really warm to the touch. Wonder if this and the battery life are normal or do i have a defective unit.
    I think this tablet has a lot of potential but 5 hrs of battery life is going to be a deal breaker.
    Ads
    Advertising world
  3. #2
    Senior Member Achievements:
    3 months registered 500 Experience Points 250 Experience Points 100 Experience Points 31 days registered
    47741
    Aug 2011
    Anacortes, Washington 98221
    122
    Thanked
    5 times
    Acer Iconia Tablet A500
    Five hours seems kind of low, do you have alot of apps running at the same time??
  4. #3
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points
    9467
    Dec 2010
    38
    Wow mine gets warm but I get 10 to 12 hours and I use it like a rented mule.
  5. #4
    Points: 3,562, Level: 37
    Level completed: 42%, Points required for next Level: 88
    Overall activity: 2.0%
    Achievements:
    1 year registered 1,000 Experience Points 3 months registered 500 Experience Points 250 Experience Points
    47065
    Aug 2011
    S.E. Michigan, U.S.A.
    359
    Thanked
    23 times
    Points
    3,562
    Level
    37
    Vizio VTAB1008, Samsung Galaxy Tab 2 10.1
    Mine gets warm, but I get about the 8-9 hours advertised. Let's see... Monday the weather was lousy, so it was in "inside day" all day. At somewhere between 9 and 10 a.m. it came off the charger. We went out for breakfast. It saw only intermittent use, as the restaurant's WiFi was kind of lame. After returning home, maybe somewhere around 11 a.m., I read a book on that tablet (nook), occasionally checked FB, occasionally dealt with email, etc., until somewhere between 6 p.m. and 7 p.m., at which time the battery level meter was down to one bar. The "under 20%" warning popped-up sometime between 5 p.m. and 6 p.m., I think.
    I keep the GPS off unless I need it the GPS running. I don't use the Bluetooth at all.
    Jim
  6. #5
    500 Experience Points 3 months registered 250 Experience Points 31 days registered 100 Experience Points
    45742
    Aug 2011
    14
    Vizio Tablet
    Mine gets warm/hot too. I thought my first tablet was defective..because it was warm. After returning the 1st and got the 2nd, it is the same thing.
    VTAB gets warm after about 20m of use.
  7. #6
    3 months registered 250 Experience Points 100 Experience Points 31 days registered 7 days registered
    50635
    Sep 2011
    7
    Vizio Via
    Mine was having this problem and it was due to the gps being enabled and utilized by the location services. Disabling that has the tablet nice and cool with better battery life.
    Sent from my VTAB1008 using Android Tablet Forum
  8. #7
    50623
    Sep 2011
    Mine is a little warm too, but acceptable. Mine is without GPS, BT, donot know if these will affect. 3600mah works about 5.5 hours web surfing and watching film.
  9. #8
    50088
    Sep 2011
    New Jersey
    VTAB 1008
    Thanks everyone for the replys. I exchanged my Vizio the other day and the new one seems to run a little cooler and the battery life is much better. I guess that I got a bad unit the first time. I am getting around 8-9 hrs now and it seems to sleep better with less power drain. My prior unit would drain power while in sleep mode almost as fast as when it was being used. this was with all services and apps off.
    Looking forward to Vizio releasing future updates that fix the SD card problem.
    Thanks Again!
Ads:
  1. Battery life
    By hazi1964 in forum Asus TF101/SL101 Forum
    Last Post: 06-23-2011, 08:21 AM
  2. Tablet Battery Life?
    By SylvieB1984 in forum Android Tablet Q&A
    Last Post: 05-26-2011, 01:08 AM
  3. No battery life... Why?
    By Zonagal in forum Huawei Ideos S7
    Last Post: 03-25-2011, 04:04 PM
  4. Battery Life
    By bigwooly in forum Sylvania Tablets
    Last Post: 03-03-2011, 12:42 PM
  5. Battery Life
    By Grimism in forum Augen Gentouch
    Last Post: 12-24-2010, 02:48 PM
does a visio tablet have a battery
is it normal for my microsoft tablet charger to get warm
is it normal for tablets to get warm
my android tablet gets hot
my tablet gets hot
my tablet gets really hot
my tablet is hot
tablet getting hot
why do tablets get hot
why does my tablet get hot
why does my tablet get so hot
why is my tablet getting hot
