Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
  1. #1
    Member Achievements:
    1 year registered 1,000 Experience Points 3 months registered 500 Experience Points 250 Experience Points
    49170
    Sep 2011
    San Diego
    46
    Thanked
    6 times
    Vtab
    Only thing left now is the battery issue
    Since the last update provides netflix the only other issue I have is the battery.
    Specifically the time it takes to charge the battery.
    I get about 6 hrs from the battery during heavy use but using the factory charger it takes over 8hrs to fully charge. not very convient when on the go
    Sent from my VTAB1008 using Android Tablet Forum
    Ads
    Advertising world
  3. #2
    47359
    Aug 2011
    North Carolina
    80
    Thanked
    1 times
    vtab1008
    The Netflix update was great, and I hope the battery issues are resolved soon. But I would also like to be able to install apps to the external sd card rather than the internal memory.
  4. #3
    Points: 3,562, Level: 37
    Level completed: 42%, Points required for next Level: 88
    Overall activity: 2.0%
    Achievements:
    47065
    Aug 2011
    S.E. Michigan, U.S.A.
    359
    Thanked
    23 times
    Points
    3,562
    Level
    37
    Vizio VTAB1008, Samsung Galaxy Tab 2 10.1
    Unless they're limiting the charge rate via an overly-conservative charge profile in firmware, I doubt you're going to see any change in this.
    Here's the deal with rechargeable batteries, in a nutshell: You can charge them fast, limiting charge depth and battery life (in number of charge cycles), or you can charge them more conservatively, achieving both a deeper charge and longer battery life.
    I have noticed the tablet doesn't get very warm while charging. It doesn't seem to get any warmer--maybe not even as warm, as it does when operating. That tells me Vizio has chosen a charge rate that will result in deeper charging and longer battery life. I think I prefer that. It jibes with their apparent philosophy on the operation of the tablet: A single-core CPU with less power, and less power drain, than other current offerings. That's why this tablet gets up to nine hours or better of operation, where others get only five or six.
    Jim
  5. #4
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    55283
    Oct 2011
    31
    Thanked
    1 times
    That's been the least of my issues. While I do typically charge overnight I've been able to consistently get 10 to 12 hrs on a daily charge with fairly heavy usage and wifi on continously. Compared to my htc Thunderbolt phone that's a lifetime.
    Until I can find a way to effectively move apps to the external sd card I'm essentially unable to install any additional apps.
  6. #5
    Points: 5,637, Level: 48
    Level completed: 44%, Points required for next Level: 113
    Overall activity: 0%
    Achievements:
    5,000 Experience Points 1 year registered 3 months registered 31 days registered 100 Experience Points
    55309
    Oct 2011
    122
    Thanked
    46 times
    Points
    5,637
    Level
    48
    Vizio Tablet VTAB1008
    Quote Originally Posted by jhaynes1230 View Post
    Can you not move the applications using the instructions at the vizio website?
    Installing applictions
  7. #6
    55283
    Oct 2011
    31
    Thanked
    1 times
    No, unless I'm mistaken, that only seems to move apps to the internal sd. I've installed a 32gb micro sd that with the exception of some media I've moved there is essentially useless space.
  8. #7
    Junior Member Achievements:
    7 days registered
    55353
    Oct 2011
    Vizio Vtab
    I use the apps2sd app to move to my sd card. Works great
  9. #8
    49170
    Sep 2011
    San Diego
    46
    Thanked
    6 times
    Vtab
    Here's the thing . charging over night (8hrs) doesn't result in a full charge. If I was getting 10-12 hrs on a full charge I wouldn't complain about the charging time either. just got the 20% battery remaining pop up after 5 hrs 23 min on the battery. try watching 30-45 minutes of you tube or netflix and see what that does to your 10-12 hr run time. I'll try without any you tube and report back.
  10. #9
    500 Experience Points 3 months registered 250 Experience Points 100 Experience Points 31 days registered
    49538
    Sep 2011
    Tennessee
    64
    Thanked
    1 times
    VTAB1008
    As with any android device it all comes down to what apps are constantly running and what one is doing. I. E. You tube, web surfing, playing games. All these different variables will cause each device to have different time spans for battery life. There is no good way to determain who does or dose not have the best battery life.
  11. #10
    Achievements:
    47065
    Aug 2011
    359
    Thanked
    23 times
    Points
    3,562
    Level
    37
    Quote Originally Posted by zsir View Post
    Here's the thing . charging over night (8hrs) doesn't result in a full charge. If I was getting 10-12 hrs on a full charge ...
    The claim is "up to 10 hours." Obvious that's depending upon use and usage.
    After doing the latest update the other night, before which my VTAB had been off the charger and I'd been web-browsing, FB'ing, using this site's app, etc. for... I dunno... two or three hours, I guess, I watched at least two episodes of News Radio, maybe three, then went back to more web-browsing, FB'ing and this site's app. I think I did some 'droid market perusing, too.
    IIRC: Had plenty of charge left following that.
    This is not something you want to do often, because the tablet may come up in an odd state after you do (it did for me), but have you ever run the thing all the way down? It's often necessary to do that with batteries, once or twice, for them to achieve full potential.
    Jim
Ads:
  1. chargeing/battery issue... PLEASE HELP
    By Killerloon in forum Gome Flytouch II Firmware
    Last Post: 10-04-2011, 12:07 PM
  2. Battery reading issue
    By androidgift in forum Toshiba Thrive
    Last Post: 08-02-2011, 11:18 PM
  3. Battery Issue Question (% Left)
    By NCNoob in forum Nook Color Technical
    Last Post: 07-28-2011, 11:26 PM
  4. Serious battery issue :(
    By raufhon in forum Huawei Ideos S7
    Last Post: 05-02-2011, 02:46 PM
  5. Battery Issue
    By AndreObi in forum Android Tablet Q&A
    Last Post: 04-05-2011, 07:17 AM
battery for vtab1008
vizio tablet battery issues
vizio tablet battery problems
vizio tablet battery removal
vizio tablet battery replacement
vizio tablet vtab1008 battery replacement
vizio vtab1008 battery replacement
vizio vtab1008 replacement battery
vtab 1008 battery replacement
vtab1008 battery
