Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thanks Tree2Thanks
Thread: Known problems?
  1. #1
    Junior Member Achievements:
    250 Experience Points 31 days registered 7 days registered 100 Experience Points Tagger Second Class
    84008
    Jan 2012
    GA
    16
    Acer Iconia A100 ~ soon!
    Known problems?
    Are there any known problems with the 8'' Vizio tablet? Are there any common issues people are having?
    Ads
    Advertising world
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    If you haven't already you may want to read trough the threads in this section as the issues are openly talked about and easy to find. The big issues are (1) the SD card in not accessible in the traditional sense for Android devices and (2) adhoc wireless networks are not supported. Both of these can be overcome by rooting the tablet. However, you can only root if you are on software version 1.4. Updating to 1.5 breaks existing root and prevents rooting.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    84008
    Jan 2012
    GA
    16
    Yeah I read about the sd card problem.. seems kinda weird. What is an adhoc wireless network? I have bellsouth.net wireless I hope that's okay to use. I have never rooted anything I hear that voids warranty. Thanks.
  5. #4
    Points: 1,656, Level: 23
    Level completed: 56%, Points required for next Level: 44
    Overall activity: 0%
    Achievements:
    1,000 Experience Points 1 year registered 500 Experience Points 3 months registered 250 Experience Points
    70832
    Dec 2011
    Nashville
    36
    Thanked
    1 times
    Points
    1,656
    Level
    23
    EVO Shift
    ad hoc is normally used to tether a wifi enabled device to your phone so you can access data through your wireless provider. for high speed internet connection through wifi you should not have a problem.
    I have had my refurb unit purchased from woot since Christmas and have had no concerns.
    LoveJC03 thanked this.
  6. #5
    1 year registered 1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points
    59412
    Oct 2011
    New Orleans, LA
    76
    Thanked
    8 times
    VTAB 1008
    Several users, such as myself, have had problems with the power port becoming very loose and unuseable. Vizio sent me a replacement. Be gentle when plugging and unplugging.
  7. #6
    250 Experience Points 3 months registered 100 Experience Points 31 days registered 7 days registered
    85035
    Jan 2012
    The app launcher crashes as regular as clockwork. This is my first ever android device and I have to say that I am not very impressed. Compared to ios this is laggy. I won this vtab in a raffle at work. Free tab too bad but buying it? I hope Vizio updates to android 4.
    Sent from my VTAB1008 using Android Tablet Forum
  8. #7
    Points: 5,271, Level: 46
    Level completed: 61%, Points required for next Level: 79
    Overall activity: 1.0%
    Achievements:
    5,000 Experience Points 1 year registered 1,000 Experience Points 500 Experience Points 3 months registered
    55822
    Oct 2011
    NE Ohio
    89
    Thanked
    23 times
    Points
    5,271
    Level
    46
    Vizio VTAB1008 - Coby Kyros MID 4331 - D2 721
    Quote Originally Posted by ariggs1 View Post
    I've had mine for over 3 months now and the app launcher has never crashed. Comparing operational speed to a tablet that costs 3 times as much is hardly fair. Still waiting to see what kind of tweaks have been made when Honeycomb update arrives.
  9. #8
    67782
    Dec 2011
    Kansas
    52
    Thanked
    1 times
    Vizio Vtab1008
    The other day while using my tablet the screen started pixalating (<-- IS that a word?) then the screen turned white. Thank God it fixed itself after I powered it off a couple of times. It's worked fine since. BUT, I did back everything to the sd card using the sandisk app.
    ~Zina
    So far the proud owner of a Vizio Vtab1008
  10. #9
    63772
    Nov 2011
    16
    Speakers a little weak gps sporadic, otherwise good at everything I want.
  11. #10
    Points: 7,400, Level: 57
    Level completed: 25%, Points required for next Level: 150
    Achievements:
    1 year registered 5,000 Experience Points 3 months registered 1,000 Experience Points 31 days registered
    84893
    Jan 2012
    St. Louis Mo
    474
    Thanked
    49 times
    Points
    7,400
    Level
    57
    iPad2 32, Toshiba Thrive 32. Lenovo IdeaPad A1, ICOO D90W
    Quote Originally Posted by J515OP View Post
    I don't understand this?
    I own one of theses and if you are holding the tablet with the button on top, the SD card access is on the bottom left side under a small plug door not any different than any other tablet or phone, and not as bad as some where you have to take the back off the phone. At least with this you just open the plug door and slide your SD card in or out like any other thing.
    To all members. Remember to thank those who help you with a problem by clicking on the "Thank" icon/link on the right of the screen in the post.
    It helps us (members) to know that we are actually helping you.
Ads:
  1. Vpn problems
    By vminea in forum Asus TF101/SL101 Forum
    Last Post: 12-30-2011, 02:24 PM
  2. Problems
    By markggriffiths1984 in forum Android Tablet Q&A
    Last Post: 12-19-2011, 05:38 AM
  3. Problems...
    By thedanish1987 in forum Acer Iconia Tab A500 Forum
    Last Post: 08-08-2011, 09:18 PM
  4. Various problems?
    By cheerful in forum Viewsonic gTablet
    Last Post: 04-02-2011, 02:14 PM
  5. 3g problems
    By AvsGrae in forum Huawei Ideos S7
    Last Post: 01-13-2011, 10:13 AM
how to fix vizio tablet charging port
problems with vizio tablet
vizio tablet battery problems
vizio tablet charger port problems
vizio tablet charging issues
vizio tablet charging port problems
vizio tablet charging problems
vizio tablet issues
vizio tablet most common problems
vizio tablet problems
vizio tablet problems charging
vizio vtab1008 problems
