04-16-2011 09:49 AM
# ADS
to connect to a PC you have to root the device. If you are having problems with your touch screen there is abn option in settings to calibrate it, try that and see if that works...if not then you may have a damaged unit and should get the people you bought it from to replace it. If you want an unchinafied version of android then you will have to flash it and put an upgraded rom onto it.
How do I root it? Is there a tutorial?
And what ROM should I use?
flashing it with an upgraded rom "should" root it for you as far as which you choose and how you load it, that info is in other threads in this forum. i cant say from experience though.
