Results 1 to 4 of 4
  1. #1
    Senior Member Achievements:
    1,000 Experience Points 500 Experience Points 3 months registered 250 Experience Points 100 Experience Points
    61272
    Nov 2011
    plymouth
    698
    Thanked
    55 times
    wm8650
    scree problems-is it g sensor or touchscreen..how do i adust???
    I'm having problems, my m703 screen is wobbling all over the place. I've tried touch calibration which works or seems to for a minute or two but then I can't do anything. As soon as I touch ormove the tab it goes haywire & needs to be turned off for a while. Could it be g-sensor or is it just a dodgy sceen? I use it fairly heavily & its running uberoid v10 if this helps.
    Sent from my WM8650 using Android Tablet
    Ads
    Advertising world
  3. #2
    Points: 2,158, Level: 28
    Level completed: 6%, Points required for next Level: 142
    Overall activity: 0%
    Achievements:
    1 year registered 1,000 Experience Points 3 months registered 500 Experience Points 31 days registered
    104433
    Apr 2012
    East Coast
    55
    Thanked
    1 times
    Points
    2,158
    Level
    28
    Acer Iconia Tab 500 (HP Tab 4.0)
    hi, sounds bad, maybe you should try a different version software. there is a version v10.1, or higher which i am looking for so far no luck. am kind of lost and just going page by page. Wish i could help you more.
  4. #3
    Points: 105,464, Level: 100
    Overall activity: 100.0%
    Achievements:
    100,000 Experience Points Veteran Overdrive Tagger First Class Recommendation First Class
    23311
    Mar 2011
    Chicago, IL
    13,600
    Thanked
    1619 times
    Points
    105,464
    Level
    100
    NOOK Tablet Stock NOOKcolor Rooted & ManualNooted Google Nexus 7 (2013) 32GB
    I saw a post a while back where similar behavior was caused by a dirty screen. It thought it was being touched even when it wasn't. If it does it when the tablet's laying down on a table or something where it isn't being moved, that would seem to eliminate the g-sensor.
    If it's important to you, you'll find a
    way. If not, you'll find an excuse.
    If you're too busy for friends,
    You're too busy.
    Attention lurkers! Join the forum,
    and enter Spider into the referrer
    field of the application.The $0.00
    USD fee will be waived.
    People will forget what you said.
    People will forget what you did.
    But, people will never forget
    how you made them feel.
  5. #4
    61272
    Nov 2011
    plymouth
    698
    Thanked
    55 times
    wm8650
    I removed the screen protector & reflashed uberoid 10.1. Works fine now but screen will get scratched. Gettin new device so not so important now.
Ads:
  1. Problems solved wm8650 7" (Touchscreen + Market + audio)
    By iamuser2007 in forum WonderMedia WM8650 Tablets
    Last Post: 05-16-2012, 07:36 PM
  2. Replies: 0
    Last Post: 11-08-2011, 05:40 PM
  3. Making camera display preview image full scree -
    By rmwilson in forum Gome Flytouch
    Last Post: 10-02-2011, 10:27 PM
  4. G-Sensor problems? Anyone? Bueller?
    By SiriusWolf in forum Gome Flytouch II
    Last Post: 05-14-2011, 05:36 AM
  5. Touchscreen problems!!!
    By stevehdevos in forum Samsung Galaxy Note/Tab
    Last Post: 05-06-2011, 07:36 PM
droid razr g sensor calibration
g sensor calibration android
galaxy tab g sensor
g?sensor not working droid razr
samsung galaxy pad 2 10.1 touch screen calibrate
samsung galaxy s2 g sensor calibration
samsung galaxy tab 10.1 touch screen calibration
tablet sensor touch screen problems
what is a g sensor on a tablet
whats a g sensor calibration
wm8650 android touch sensor replace
