Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
  1. #1
    Junior Member Achievements:
    7 days registered 31 days registered 100 Experience Points
    100967
    Mar 2012
    England
    11
    Mid Tablet (Unknown)
    Talking Tablet Won't Power On
    Hi, I bought this wondermedia based tablet off ebay, sold as faulty, to see if I could get it working. I have taken it apart and cannot see any problems that could occur from the hardware. If I plug it in the charge light comes on and everything but if I try to turn it on, plugged in or not, nothing happens, no light or anything. Any ideas? Thanks.
    Ads
    Advertising world
  3. #2
    Super Moderator Achievements:
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Test the actual battery and see if it has any charge. See if you can unplug it where it connects to the device and see if it has any juice with a multi-meter.
    Nexus 7
    Nook Color -
    (eMMC): CM10 Nightlies
    Nook Tablet 16GB: Jelly Bean
    VTAB1008: Rooted Gingerbread
    Android OS Help & How To
  4. #3
    100967
    Mar 2012
    England
    11
    I tested it with my makeshift multimeter, and you're right, nothing is coming through. Surely though, if it's plugged in it should still power on? What can I do now I know the battery doesn't work?
  5. #4
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Quote Originally Posted by Iskuri View Post
    Not necessarily. It sounds like you need to find where the circuit is broken. Check the leads coming into the battery from the device with the device plugged in to see if the power is coming through. Not sure how the charge light works but that doesn't mean the device is getting power when plugged in, just that the light is.
    Nexus 7
    Nook Color -
  6. #5
    100967
    Mar 2012
    England
    11
    Good point! I tested it while it was plugged in and there was indeed no power being transferred to the battery, anything I can do about that?
  7. #6
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    My next step would be to carefully examine the port where the charging cable connects to the device. See if there are any noticeably loose connections right where the power is supposed to be coming in. It is not uncommon for the micro usb ports to break since that is a weak point in most tablets. Maybe you can find a simple disconnection that can be soldered or repaired.
    Nexus 7
    Nook Color -
  8. #7
    100967
    Mar 2012
    England
    11
    I'll have a look, it's very odd to me that the light comes on but the battery isn't charged. It's making me tempted to just patch the led's power straight into the battery haha.
  9. #8
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    Strange yes. I wouldn't be surprised though if the led draws directly or nearly so from the port. Particularly if it is located near it. It would be simple to tie into the power directly rather than pulling it someplace else off the board.
    Nexus 7
    Nook Color -
  10. #9
    100967
    Mar 2012
    England
    11
    Are you saying there's a way to make the tablet draw power from the mains itself? Because that'd be really useful! I'm going to have to find out why there's no power going to the battery.
  11. #10
    12338
    Jan 2011
    Northern CA
    5,174
    Thanked
    899 times
    No, just that the charging led indicator may work that way. For example inserting the hot charging cable into the micro usb simply creates a physical connection that both completes the circuit to the led indicator and powers it. While examining the micro usb you might be able to see how the led charge indicator is powered.
    Powering the actual device is another issue. It would interesting to know if it would run if the battery had power even though the battery can't get power from the charger to recharge. Since it won't run being plugged in though I suspect the power isn't making it very far beyond the micro usb connector. It might be toast unless you are able to find an easy disconnect that can be repaired or are a hardware expert.
    Nexus 7
    Nook Color -
Ads:
  1. New 10.2" tablet won't power up?
    By svetetr84 in forum Zenithink ZT180 10 Generation 1
    Last Post: 11-18-2012, 09:55 PM
  2. Alphapad android 4.0 tablet won't power on
    By AshNicole in forum Android Tablet Q&A
    Last Post: 04-11-2012, 08:34 PM
  3. Tablet won't power on
    By suthernwoman1981 in forum Android Tablet Q&A
    Last Post: 04-01-2012, 02:36 AM
  4. Flytouch 3 10 inch Android Tablet - Power-up/Power-down ?
    By jonatec in forum Android Tablet Q&A
    Last Post: 10-20-2011, 02:44 AM
  5. aishuo tablet power supply
    By gstab in forum Aishuo Tablets
    Last Post: 06-14-2011, 04:12 AM
android tablet won't power on
my vizio tablet wont turn on
vizio tablet vtab1008 wont charge
vizio tablet vtab1008 wont turn on
vizio tablet will not turn on
vizio tablet won't turn on
vizio tablet wont charge or turn on
vizio vtab1008 wont charge
vizio vtab1008 wont turn on
