Results 1 to 7 of 7
  1. #1
    Junior Member Achievements:
    1,000 Experience Points 500 Experience Points 250 Experience Points 1 year registered 100 Experience Points
    1477
    Aug 2010
    Thanked
    3 times
    USB Enthernet cable Connection
    I have a 8" Apad with a mini usb cable is there anyone who knows where I can find a usb enthernet adapter. I purchased a usb enthernet adapter but it requires a cd download I ran on laptop but the files are all for windows or is there way to transfer that data I don't it will work google android OS. Also I have 7" Epad (battery dead) that has one of those external usb/enthernet adapters could I connect the usb from the Apad into the Epad adapter and then connect my enthernet line.
    Ads
  3. #2
    Super Moderator
    Points: 70,539, Level: 100
    Overall activity: 0%
    Achievements:
    Veteran 50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points
    Awards:
    User with most referrers
    688
    Jun 2010
    Gilbert, Arizona
    1,839
    Thanked
    137 times
    Points
    70,539
    Level
    100
    no each tablet has specific drivers just for that tablet it would be easy to just buy a wireless router and set that up and then connect you tablet through wifi
  4. #3
    1 year registered 1,000 Experience Points 500 Experience Points 250 Experience Points Tagger Second Class
    3357
    Sep 2010
    Center of Utah in the USA
    58
    Thanked
    1 times
    Treo Pro for now
    ethernet with an android tablet
    I saw the recent 10 inch zenithink tablet comes with an ethernet dongle.
    Do any of the 7 inch tablets like the Hero RK7 or the WiTS A81 come with an ethernet dongle?
  5. #4
    Senior Member Achievements:
    1,000 Experience Points 500 Experience Points 250 Experience Points 100 Experience Points Tagger Second Class
    1547
    Aug 2010
    Michigan
    514
    Thanked
    12 times
    Waiting for a good iPod Touch Android Device
    i'm sure you could get a old used router on ebay for crazy cheap.
  6. #5
    227
    May 2010
    133
    Thanked
    8 times
    Quote Originally Posted by Vernon17 View Post
    Yes, some do, like this: DealExtreme: $104.90 7" Touch Screen TFT LCD Google Android 1.6 Tablet PC w/ WiFi/Camera (VIA WM8505 ARM926) - But those I've seen have the VIA chipset...
  7. #6
    3357
    Sep 2010
    58
    Thanked
    1 times
    Treo Pro for now
    Yes! That is the very type of thing that I am looking at. A Shanzi unit called LanPad has the same connector.
    The ethernet is important to me because in my work I have to use a physical connection to test ports on Cisco switches.
    thanks ZilverZurfarn.
  8. #7
    Developer
    Achievements:
    50,000 Experience Points 25,000 Experience Points 10,000 Experience Points 5,000 Experience Points 1,000 Experience Points
    1423
    Aug 2010
    USA
    1,505
    Thanked
    107 times
    COBY KYROS 7015 | 7015A
    Shown above with LAN port connected and two USB ports. You do know you can use iTouch connector with USB also with this device.
    PowerCode 1000 DCX
    Coby Kyros 7012, 7015, 7015a, 7016, 7022, 7042, 7125, 7126, 7127, 8125, 8126, 8127, 9742, 1042, 1125, 1126 (Gingerbread, Ice Cream Sandwich, Jelly Bean)
    Skytex Skypad Alpha, Gemini (Ice Cream Sandwich)
    Visual Land Connect, Prestige Ice Cream Sandwich)
    45x Tablets Owned/Tested/Configured/Tweaked/GUI: Running OS: 1.6, 2.0, 2.1, 2.2, 2.3, 3.0, 4.0, 4.1 | Since 2010
Ads:
  1. internet connection problem on Eken M001
    By roymattblack in forum WonderMedia WM8505 Tablets
    Last Post: 07-23-2010, 04:16 AM
adapter usb to erthnet for tablet android
android ethernet connection
android micro usb 3 to 1000mbs lan adapter
android tablet ethernet connection
android usb to ethernet connection
can a tablet have an ethernet connection
how to add ethernet to an android tablet
prototec tablet ethernet connections
tablet charging and ethernet cable
tablet to ethernet connection
tablet with ethernet connection
