Achievements:
Zt 280 C91 Insufficient Memory Problem in Marketplace
I recently bought a ZT 280 c91 . Had loaded some new apps from the marketplace and everything worked fine. I turned it on one day and some apps were missing and when I went into the marketplace and tried to re download the apps it tells me that there is insufficient space. I've checked internal and sd card space and all shows plenty of space. I'm new to android . Any suggestions what I can do next? Thanks in advance.
01-31-2012 09:38 AM
# ADS
Achievements:
Originally Posted by
rjjtraina
By default, apps are stored in the device's internal memory (NAND Flash) and not on the SD card. Is it possible that you have filled-up the internal memory with lots of music/photos/videos? You can check this by going to the Settings and choosing Storage Settings. The first two entries there (on Android 2.3.4) show you Total Space and Available Space. If your Available Space is very low, that would be your problem and you should find something to delete (using one of the File Manager products that are installed by default).
Mine has the same problem.
It will be fine for days, Then one time you turn it on it shows missing apps, you goto Device info and internal storage is 0. And i dont know how to fix it. ANY Ideas PLEASE?
