Results 1 to 8 of 8
Thanks Tree4Thanks
  • 1 Post By mumof4girlz
  • 2 Post By jimbo7630
  • 1 Post By jimbo7630
Thread: sd card not being read
  1. #1
    93734
    Feb 2012
    uk
    Thanked
    1 times
    Zetab c9 4.0
    my husband bought me this tablet which arrived yesterday, when he bought it it came with a 32gb sd card, but when its put in it does not register that a card has even been put in, its the c91 with the lastest 4.0 with ice-cream sandwhich (im not techi at all, so not sure what all that means i hope you do, have you any ideas? its not the sd card that is faulty i have tried a 2gb card and also a 1gb card and none of them are being achknowledged..............please please help
    monradon thanked this.
    Ads
    Advertising world
  3. #2
    jimbo7630
    Guest
    Have you tried going into Settings>Storage>External SD card? if it shows there it is being read.
    Edit: If, however, it gives you the option to "Mount SD Card" then you have to click/press on that.
    mumof4girlz and monradon thanked this.
  4. #3
    93734
    Feb 2012
    uk
    Thanked
    1 times
    Zetab c9 4.0
    hi, thanks for quick reply, ive just tried that, it does say mount sd card, but its in grey, it wont do anything when pressed :-s
  5. #4
    jimbo7630
    Guest
    If it is greyed out it is non operative, try removing the SD card and re-inserting, also try removing the card and switching off before re-inserting and also inserting the card when switched off then doing the Settings thing to see if you can mount it.
    mumof4girlz thanked this.
  6. #5
    93734
    Feb 2012
    uk
    Thanked
    1 times
    Zetab c9 4.0
    ha ha oh dear well i feel a fool, the most basic fix, turn it off and on again, wish id thought about that before stressing fro the past 36 hors that we had been sent a dodgy tablet thanks soooo much
  7. #6
    jimbo7630
    Guest
    We all feel kinda foolish, WHEN WE KNOW THE ANSWER! glad it worked!!
  8. #7
    138979
    Aug 2012
    England
    All original winter tablet android 4.0
    Hey jimbo, I am having the same problem, and have tried all your solutions, when I go into settings, it comes up that settings has stopped, my music simply comes up with "there has been an error" and then shows up with 3 songs that came with the tablet,
    I am very confused.
    If anyone could help, it would be much appreciated,
  9. #8
    Points: 33, Level: 1
    Level completed: 66%, Points required for next Level: 17
    Overall activity: 9.0%
    193450
    Apr 2014
    Australia
    Points
    33
    Level
    dgtec
    i am having the same problem. settings works on everything but when i hit storage it stops. in file manager storage/sdcard i get the message 'Directory is read banned'. i have checked the sd card, it works fine in the PC and tried another. I see there has been no reply yet, so is this problem unsolvable.?
Ads:
  1. won't read sd card?
    By alekos557 in forum Android Tablet Q&A
    Last Post: 08-18-2011, 02:43 PM
  2. After burning CM7 to SD card I can't read the card
    By durendel in forum Nook Color Technical
    Last Post: 08-05-2011, 09:17 AM
  3. Flytouch 2 will not read MicroSD card.
    By Alasdair Hutchison in forum Gome Flytouch II Accessories
    Last Post: 04-27-2011, 08:46 PM
  4. How to read TF or Micro SD card with your tablet?
    By exnoiuh in forum Android Tablet Discussions
    Last Post: 04-24-2011, 12:47 PM
  5. Can we read images from SD CARD or USB
    By ranjiths26 in forum Android Tablet Q&A
    Last Post: 04-10-2011, 10:55 AM
android tablet not reading sd card
my sd card wont read on my tablet
my tablet does not recognize sd card
my tablet is not reading sd card
my tablet wont read my sd card
sd card ot recognized on tablet
tablet not recognizing sd card
tablet wont read sd card
tablet wont recognize sd card
why wont my tablet read my sd card
