3G, how does it work?
Discussion in 'APAD G10' started by TabletBox, Jun 10, 2011.
  1. TabletBox
    TabletBox Member
    Netherlands
    APAD G10, MID815, MID816, HaiPad M701-R
    Hi Guys,
    Just got our G10 (3G version) from Utopia itself.
    Wondering how the 3G works.
    Anyone got an idea?
    Also, when the Sim Card is inserted it rejects the PIN code 99% of the time.
    (PIN code is correct!) So we get stuck at the "enter your PIN code" screen.
  2. mikers
    mikers Member
    Dawa on my USB modem does not work, "Huawei E1750."
    I have tried various methods, the tablet does not see it.
    You know a USB 3G modem that will work?
  3. darmadi
    darmadi Member
    Jakarta
    10" Apad Cortex A8
    Yup mine not working either, try half a dozen modem, no reaction, the mdem blinking though
    Sent from my imx51_bbg using Android Tablet Forum
  4. danvj
    danvj Member
    The internal 3G module is doing the same thing to me. I read several articles on the internet and did everything they tell but in the end I came with no solution. I tried to unable the sim pin verification but even with no sim card in it, it tells me I've entered the wrong code. I emailed the store I ordered the tablet to see if they can come up with a solution, if I have any luck I'll make sure to post here. In the mean time, any solutions/suggestions would be great ^^
do tablets work on 3g
if a tablet is 3g how does it work
