7016 Unable to get Flash Running
WVUTampaAlum
77
I've got a 7016-4g. It is not rooted but I used another link on this forum for the 7024 to install market. I've been unable to get flash working. I've tried install/uninstall and installing other flash versions and nothing. I'm using dolphin hd. People who got flash working what method did you use?
Below are flash versions that did not work.
10.3.186.6
10.3.186.25
lfom
Developer
Sep 12, 2011
1,386
239
Your tablet uses a Telechips ARM 11 processor, you should be able to find more info in other areas of the forum (this one is for models with Samsung S5PV210 processor). Search for "7016 flash". ;)
Hmm, I think you did since I saw other posts from you in another thread. Short answer: I guess Flash won't work in Telechips ARM 11. You may want to look for a "patched" or modded version for your processor, I think I've seen one for 7015. It was version 10.1 if I am not mistaken...
trickbiker121
162
25
Flash with dolphin HD does not work well. Try the stock browser and now it should work.
WVUTampaAlum
77
Nothing has worked for me and doing a lot of searching and research it appears rooting the 7016 is not currently working for anyone. If someone has flash or root of 7016-4g please let me know how you did it.
lfom
Developer
Sep 12, 2011
1,386
239
I've found this in a Brazilian forum:
Adobe Flash Player 10.3.apk - 4shared.com - online file sharing and storage - download
who posted it said that it worked with stock ROM but not with CM7 mod.
If it doesn't work, try some link for 7015 (almost same hardware, right?). I have seen some videos on Youtube about Flash running on 7015.
WVUTampaAlum
77
Does it give you an error when installing?
No error for any version I've tried. Right now I have some 10.1 version someone got working on there 7015.
Sent from my MID7016 using Android Tablet Forum
fickletrick
This works for my Kyros 7016:
adobe_flashplayer_10.2.157.340.apk
DepositFiles
10.3.186.6
10.3.186.25
