7024 wall charger?
Bigsteve
will the 7024 charge through the usb and if not what are the specs for the wall charger? amps, volts size plug ? i bought a unit of ebay, its in the mail, but does not come with a charger.
thanks
Bigsteve
great thanks. should be able to pick up some type of universal one at walmart or radioshack. if i can find the right tip
Bigsteve
ok so tablet still not here but i found a 9v 1.2a (1200ma) charger in my box of odds last night and am wondering if i can use this. if it has the right tip.
being as it is less amps does that mean that it will just take longer to charge?
bily95
I guess so, you have two option, either it will charge slowly, or not at all... it all depend of the 7024
