8024 ribbon cable help
wbsjr99
I have a Kyros 8024 and the screen image was very faint. I removed the back cover and found that the ribbon cable was half out of the main board socket, I tried to push in , now it is all the way out and I am having trouble getting it back in. Is there a trick to this?
I don't want to force the cable as it seems fragile. Does anyone know if the main board socket snaps off to allow proper placement, I have searched the web and no info is available.
Thanks.
lfom
Developer
Sep 12, 2011
1,386
239
Usually you have to lift a movable part of the connector so you can insert the cable, then close it to lock...
