88% battery charge
Discussion in 'Gome Flytouch II Variant 2' started by comoeuamais, May 4, 2011.
  1. comoeuamais
    comoeuamais Member
    Lisbon
    Flytouch 3
    Hello everyone
    I have a Flytouch3 (Superpad2) for about 2 days and I have an issue with my battery.
    I can't charge more that 88% of the battery. Anyone experience something similar to this?
    I'm only have about 1h ~1h half running video and about 2h~2h half playing with pictures, music...
    I already charge the battery for 8h and still indicates me 88%, never passed to 100%.
    Any advice from you? What can I do to solve my problem.
    Already turn off Wifi, reduce the brightness, turn off sync and so one.
    Please I will appreciate your advices
  2. bratcat
    bratcat Member
    Canada
    I had the same problem with mine. It would get to 88% charge quickly then seem to sit there for a long time. It does however get to 100%, just took longer than normal. I also had the problem of the battery draining quickly. I installed android assistant to help with battery issues, plus I turned my GPS off. I saw the satellite signal streaming from my tablet but didn't realize it was my GPS until I had my tablet for about a week. It was draining my battery quickly and once I turned it off my battery life has improved significantly.
    • Like Like x 2
  3. comoeuamais
    comoeuamais Member
    Lisbon
    Flytouch 3
    Thanks bratcat, what did you used to turn off the GPS?
  4. uplade3
    uplade3 Super Moderator Staff Member
    Asheville N.C.
    Flytouch II/SuperPAD Droid Charge/Razr, Galaxy S4
    Also, you can turn off the cell standby process to save battery.
    • Like Like x 2
  5. comoeuamais
    comoeuamais Member
    Lisbon
    Flytouch 3
    Already have all things ready to do it except the z4root program, w'll install today to see if works.
    Thanks to both
  6. bratcat
    bratcat Member
    Canada
    The GPS is located under settings ---> location/security ----> use GPS satellites
    Make sure it is off (not highlighted). Once you do this the satellite icon that appears on your tablet will stop its transmission and your battery life will improve.
    • Like Like x 2
  7. comoeuamais
    comoeuamais Member
    Lisbon
    Flytouch 3
    GPS off and turned off the cell standby process.
    Tomorow I will see the results
    Thanks people!
  8. comoeuamais
    comoeuamais Member
    Lisbon
    Flytouch 3
    Thanks people, everything work as expect.
    Battery is now 3~4hours
    Playing video ~2h
android battery only charges to 88
android battery stuck at 88
galaxy s3 only charges to 88
galaxy s3 only charging to 88
galaxy s3 stops charging at 88
my phone wont charge past 88
my s3 only charges to 88
my samsung galaxy s3 wont charge past 88
shield tablet only charges to 88
