I have a 9042 that I managed to brink 1/2 back to life. it turns on, into debugging mode. but It will not boot into recovery no mater what I do. I can access in adb but when I try to: su it will say permission denied. I try to re-install recovery and also permission denied. any ideas on how to regain permission?
also es file explorer is gone and I can not reinstall because the partition is bad, it is out of space with no apps installed.
it was rooted, and I tried re rooting it. I follow all the instruction and when I get to: /data/local/tmp/install-recovery.sh it gives me this error: cannot create /dev/block/nandg: permission denied
type adb shell mount also post what you did to your tablet to get it into this shape. "error: cannot create /dev/block/nandg: permission denied" usually means you are doing this on unrooted tablet. when you tpye adb commands do you see $ or #?
C:\Users\Todito\CobyADB>adb shell shell@android:/ $ mount mount rootfs / rootfs rw 0 0 tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0 devpts /dev/pts devpts rw,relatime,mode=600,ptmxmode=000 0 0 proc /proc proc rw,relatime 0 0 sysfs /sys sysfs rw,relatime 0 0 tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0 tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0 /dev/block/nandd /system ext4 ro,relatime,user_xattr,barrier=0,data=ordered 0 0 /dev/block/vold/179:1 /mnt/extsd vfat rw,dirsync,nosuid,nodev,noexec,relatime,ui d=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset= ascii,shortname=mixed,utf8,errors=remount-ro 0 0 /dev/block/vold/93:64 /mnt/sdcard vfat rw,dirsync,nosuid,nodev,noexec,relatime,u id=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,iocharset =ascii,shortname=mixed,utf8,errors=remount-ro 0 0 /dev/block/vold/93:64 /mnt/secure/asec vfat rw,dirsync,nosuid,nodev,noexec,relat ime,uid=1000,gid=1015,fmask=0702,dmask=0702,allow_utime=0020,codepage=cp437,ioch arset=ascii,shortname=mixed,utf8,errors=remount-ro 0 0 tmpfs /mnt/sdcard/.android_secure tmpfs ro,relatime,size=0k,mode=000 0 0 shell@android:/ $ as you can tell I see$ as far as what happened it auto updated busybox and it started givving me just black screens when I went into apps. I uninstalled busybox and when I rebooted it was stuck on the coby letters. I could not get it to see adb in recovery so i found a zip image on the net and installed it. it brought it back, but only half way and now it will not go into recovery or let me change anything with adb..
hardware key will not work. power plus volume will not work. it will boot like normal. I will try livesuite, but i am unsure if it will work when it is not in recovery. thanks!!
tried livesuite. does not work either. tried both debugging mode and normal. as soon as I hit run livesuite shuts down.
