9742 MBR problems and such post here.
Discussion in 'Coby Generation 3 Development' started by vampirefo., Jun 9, 2012.
  1. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    You assume the risk this or any modification could possibly brick your tablet
    Ok from what I have read some of you guys have upside down screens, this usually can be fixed via MBR, aka bootloader.
    You need adb setup and working if you have a filemanger that has root access this would be great.
    anyway download bootloader files.
    9742_BOOTLOADER.ZIP
    extract some where, on your sdcard would be nice. if you want to use file manger.
    adb shell
    mkdir /sdcard/na
    mount -t vfat /dev/block/nanda /sdcard/na
    exit
    if you placed the files on sdcard, and have file manger with root access, navigate file manger to /sdcard/na/ delete script0.bin and script.bin then navigate to /sdcard/na/linux and delete u-boot.bin.
    then use file manager and copy the script0.bin and script.bin you downloaded to /sdcard/na/ and copy the u-boot.bin you download to /sdcard/na/linux you are just replacing 3 files.
    if you want to do via adb you can skip the file manager stuff and just push the files.
    adb push script0.bin /sdcard/na/
    adb push script.bin /sdcard/na/
    adb push u-boot.bin /sdcard/na/linux
    in either case reboot.
    Do not reboot until you have copied each of the 3 files to where they need to go, if using file manger do a dry run make sure you can find the files that need to be replaced, and where they go before doing anything.
    • Like Like x 4
  2. Shini
    Shini Member
    MID9742
    Hi vamp, thanks for the help.
    Just another question (sorry):
    Since I'm an windows user I don't know if the command line "mount -t vfat /dev/block/nanda /sdcard/na" could be replaced for any windows command. Those for adb I can reproduce.
    I have downloaded Ubuntu, I'll try to configure adb and jdk.
  3. vampirefo.
    Huntington WV
    You don't need Linux for the mount command, that is being done on the tablet itself through adb shell.
  4. Shini
    Shini Member
    MID9742
    I did it, I have delete the old ones and copied the new ones. The sensor is not working now. Any Idea?
  5. vampirefo.
    Huntington WV
    sensor? is your display correct now, or is it still upside down?
  6. Shini
    Shini Member
    MID9742
    The display is OK but the touchscreen sensor is not working.
    The problem was with the touchscreen sensor, axis inverted.
  7. vampirefo.
    Huntington WV
    Yes, it's not suspose to you not work cause you have wrong boot.img and system installed, what we are working on here right now is display, can only fix one problem at a time.
    • Like Like x 2
  8. Shini
    Shini Member
    MID9742
    How can we fix the problem with the boot.img? Before, the touchscreensensors were inverted, now they are not working. Th big problem here is the sensor, I think was was not clear. Sorry.
    Should I try anything else to restore? Maybe use livesuite again...
  9. vampirefo.
    Huntington WV
    Touch screen work before? touch screen work while display was upside down?
  10. Shini
    Shini Member
    MID9742
    Man, I really was not clear, I'm so sorry. The screen was always OK. The problem was with the touchscreen sensor, the axis were inverted. Left goes right, up goes down... (axis x and y inverted)
  11. vampirefo.
    Huntington WV
    ok just download below and extract, copy the u-boot.bin you download to /sdcard/na/linux then reboot.
    u-boot.bin.zip
    adb shell
    mkdir /sdcard/na
    exit
    Just like first post but this time just one file.
  12. Shini
    Shini Member
    MID9742
    Did it. Not working.
    If I put the wrong rom again (old 9742) will it work (even if inverted axis)? Maybe it is the best solution by now...
    I have A backup of the old files, I'll put them in their places again.
  13. vampirefo.
    Huntington WV
    9742_senconf.zip
    replace these files and reboot you will be just like you were.
    • Like Like x 2
  14. Shini
    Shini Member
    MID9742
    Thanks, it is working again, with inverted axis unfortunately =(
    Is the touchscreen problem related to boot.img? Can we overwrite only the boot.img content data in the tablet?
  15. vampirefo.
    Huntington WV
    There seems to be many different problems going on with you 9742 guys, your only problem is inverted axis, while others have upside screens, and others have other problems, your problem has little to due with boot.img seeing you have touch screen, that's what the boot.img is doing, so you have correct boot.img.
    looking at both boot.img the difference is insmod /system/vendor/modules/gt8110_2plus1.ko insmod /system/vendor/modules/gt2005-2015.ko, we could force load them on your tablet might fix the problem might not, problem is you might not know what to do if anything goes wrong, if anything goes wrong. if i had the tablet here I could fix it without any trouble, but trying to test and trouble shoot via second party is very hard.
9742modules
after flash rom x axis inverted tsblet
android app to fix screen x axis inversion
android mbr
android mbr file
coby kyros mid 9742 system vendor modules driver
display axes inverted after update on android
email 40568
flash android x axis inverted
how to change touchscreen axis through rooted
how to fix android inverted touch screen
inverted axis 9742
mbr file on root explorer android
mbr tablet
mbr tablet email address
mbr tablets
mid 9742 modules axis
problem inverted touchscreen troubleshoot
tablet touchscreen inverted
touchscreen invert tablet gt2005
