Ac3 audio in MKV/AVI
Discussion in 'Telechips TCC8902 Tablets' started by CrzyHorse, Jan 17, 2011.
  1. CrzyHorse
    CrzyHorse Member
    Napoli, Italy
    Smartbook Surfer
    Does it is supported? I have smartbook surfer with iMito 1.2 firmware and it cannot play ac3 audio. Is it a firmware problem?
    Do you have any suggestions?
  2. xaueious
    Canada
    Encode the stream into something else...
  3. CrzyHorse
    CrzyHorse Member
    Napoli, Italy
    Smartbook Surfer
    Thank you for reply, but I don't think this is a solution. I find on smartbook site this pdf http://smartbookservice.de/SmartbookSurferCodecs.pdf
    AC3 should be supported, so it may be a problem with iMito firmware I put on it...Do someone have similar device with working ac3?
  4. Loonix
    Loonix Member
    NULL
    Audio tracks in AC3 (identifyed by VLC as 'a52 Audio (aka AC3)'
    play perfectly fine on my M701-HDMI 2GB @#181
    the AC3 is embedded in a MKV.
    The Video is encoded in 720p H264 MP4 AVC.
    (no alternate audio streams or subtitles are embedded)
    My m701 was not able to play Audio in a 1080p MKV with 'DTS' audio.
  5. xaueious
    Canada
    If you have a sample file, I can try it on my X5A
  6. CrzyHorse
    CrzyHorse Member
    Napoli, Italy
    Smartbook Surfer
    Thank you, this confirm that the tablet can read and that probably it is a firmware problem.
    How do I pass the file? I founded a 10MB file on 4shared with ac3, rip of Clash.of.the.Titans. As I think it is copyrighted, I cannot post link. I can't find how to send private messages..any suggestions?
  7. CrzyHorse
    CrzyHorse Member
    Napoli, Italy
    Smartbook Surfer
    I've tested original smartbook surfer and dawa firmware. Both can read ac3 in mkv/avi.
    I've tried to push all files in smartbook surfer system/lib dir on the tablet with imito firmware (that is the best, in my opinion) and it can read ac3.
    As I don't want to replace all files, as tablet may be less stable, I'd like to replace only minimum set of files to enable ac3 decoding. I put these files there were not present on iMito but ac3 is still missing:
    libdvbt.so
    libdvbt_jni.so
    libisdbt.so
    libisdbt_jni.so
    libOMX.TCC.ac3dec.so
    libOMX.TCC.alsasink.so
    libOMX.TCC.bsacdec.so
    libOMX.TCC.clocksrc.so
    libOMX.TCC.DVBDemux.so
    libOMX.TCC.DVBTTunner.so
    libOMX.TCC.DxB.audio.so
    libOMX.TCC.DxB.AudioDec.so
    libOMX.TCC.DxB.VideoDec.so
    libOMX.TCC.DxB.VPUDec.so
    libOMX.TCC.fbdevsink.so
    libOMX.TCC.image_fbdevsink.so
    libOMX.TCC.ISDBTDemux.so
    libOMX.TCC.ISDBTTunner.so
    libOMX.TCC.PADParser.so
    libOMX.TCC.tdmbdemux.so
    libOMX.TCC.tdmbrec.so
    libOMX.TCC.tdmbtuner.so
    libtdmb.so
    libtdmb_jni.so
    Any suggestion on which file I should put?
  8. DaveS
    DaveS Member
    Russia, Saint-Petersburg
    FG8, OPAD M88
    To make AC3 work in movies you need to push 2 files from DAWA or Smartbook surfer firmware to system/lib/ directory:
    libTCC_CDK_CONFIG.so
    View attachment $AC3_IMITO.zip - script and 2 files (without adb)
    View attachment $AC3_MALI_USB_FIX_IMITO.zip - automatic script including adb to patch iMito v1.2 - AC3 in video, fixed mali video driver, fixed build.prop, added libusb.so (if you whant to use it with different ROM - edit your build.prop)
    This patch files are only for Telechips 8902 Android 2.1 system.
    Don't forget to make backup!
    AC3 sound in movies on Android 2.3.3 ROMS here.
a52 audio codec for android
a52 audio codes for android
ac3 audio lib android
ac3 audio support video player apk less than 10mb
ac3 audio supported player download apk androied
ac3 codec Android
ac3 sound android
ac3 tablet
android avi ac3
android play avi ac3 sound
audio ac3 tablet
avi ac3 player android
avi ac3 pleyar apk
avi with ac3 sound player for android apk download
codec a52 audio android
codec ax3 apk
download a52 audio codec for android
download audio codec for a52 audio aka ac3 for android
how to stream vlc to android ac3
play avi on android ac3
