Acer A100 Wifi problems anyone?
Discussion in 'Acer Iconia A100' started by desolateplanet, Aug 18, 2011.
  1. desolateplanet
    desolateplanet Member
    xoom and a100
    The first A100 i purchased would not maintain a Wifi connection. I have a belkin N router. If I was more than 15 feet away from my router it would say poor connection. My xoom in the same spot would show good connection. Sitting next to my router I watched the connection go from good to "no internet connection" then back to good multiple times. I called acer and spoke to an foreign individual who told me "wifi only works for about 15 feet."
    I then returned the tablet and now have my second one. This one shows good connection where it should but cuts out the same as the other one.
    Before you blame the router, I have never had problems with the following devices...ipad, samsung tab 7, ipad 2, xoom, htc evo, multiple iphones, nook color, laptops, and even a desktop with usb N adapter.
    Anyone else having this issue?
  2. Mike02z
    Mike02z Member
    United States
    Acer Iconia A500
    No issues at all here with my Cisco E3000 router. I would say take it to a hotspot or friends house and see if it maintains it's connection. If it does it's some incompatibility with your router or an issue with your router. If you still have the issue at a hotspot you might want to exchange it.
  3. desolateplanet
    xoom and a100
    Tried it at work with a different router and results are the same. I have also noticed apps missing from the market! Words with Friends is nowhere to be found. Words with Friends shows up on my xoom. The scrabble app only fills the upper left portion of the a100 and wierd circles start apearing on the edge of the app.
  4. alphawave7
    alphawave7 Member
    San Fran
    Nook Color
    Apps issue is typical for brand new hardware and OS. Are you actually losing connection?
    Sent from my A100 using Tapatalk
  5. Skipuppy
    Skipuppy Member
    Texas
    Acer A500;Acer A100
    I have the Acer A100 and it is not experiencing any wifi problems. Connecting to either Airport Extreme or to an Airlink router it performs the same as other devices. I can connect from about 40 feet away through a couple of walls. it sounds like you A100 may have a problem - the second one could be from the same batch as the first one. Follow Mike02z's advice and you should be able to figure it out. good luck!
  6. desolateplanet
    xoom and a100
    Purchased new router Netgear N 300 and have not had connection issues. Guess the belkin and a100 didn't like each other! New problem Amazon kindle app force closes everytime i try to open a book!
  7. alphawave7
    alphawave7 Member
    San Fran
    Nook Color
    Ha! You're managing to 'find' all the known issues...do you beta-test much!?! :D
  8. jlroesler
    jlroesler Member
    Fort Mill, SC
    Acer Iconia A100
    I'm having the same issue with wifi, it keeps cutting out. I do also have a Belkin N Router. I'll try it at my son's house and see if it has any problems with his Linksys. I wonder if there is a setting I can change on the router to make it work?
  9. Spider
    Chicago, IL
    Some people have changed from WPA/WPA2 to WEP and claimed it worked. Worth a try?
  10. beastman
    beastman Member
    Austin, TX
    gtab
    I had a coworkers tablet and wifi wasn't working. I saw a switch and tried moving it. That fixed it.
  11. kqboat
    kqboat Member
    I've got an A100 and have been able to successfully connect to a Linksys E2000 running DD-WRT and another on stock firmware. No problems with connectivity
  12. bladerunn3r
    bladerunn3r Member
    Fort Worth
    Acer Iconia a100
    I don't think mine has any problems - however, on my home wifi my tab says its only getting a 50 percent signal ...which makes me a little suspicious ........mmmmm
    Sent from my A100 using Android Tablet Forum
  13. bladerunn3r
    bladerunn3r Member
    Fort Worth
    Acer Iconia a100
    @Desolateplanet - You whine like a little girl. Just return it if you hate everything about it. Or if you can't return it, then throw it away, and stop wasting your time on internet forums. Good luck, I hope you can move on with your life.
  14. desolateplanet
    xoom and a100
    @bladerunn3r..I hope you are not as dumb as your photo suggests. Considering you misspelled your own city "Fort Wort", i believe you are. For anyone interested in this product, DO NOT BUY! Or you will end up taking Bladerunn3r's advice and just throwing it away.
  15. Jv90
    Jv90 Senior Member
    Ecuador
    Sylvania Mini Tablet Express
    well IM certainly looking to buy one Acer a100 tab, you guys mean that it has some trouble regarding wifi connection?
    Sent from my Sytabex7 Tablet using android forum
acer a100 poor wifi
acer a100 weak wifi
acer a100 wifi issues
acer iconia a1 not connecting to wifi
acer iconia a1 wi-fi connection problems
acer iconia a1 wifi issues
acer iconia a1 wont connect to wifi
on my acer tablet how to remember wifi pass
use my google account to connect to an AT&T Acer phone
why wont my icer iconia one 7 remember my wifi password
