Acer A500 - problem with HDMI port
Discussion in 'Acer Iconia Tab A500 Forum' started by jak, Jul 31, 2011.
  1. jak
    jak Member
    Acer A500
    I purchased an Acer A500 about 2 weeks ago, and I think it is GREAT, but I am having a problem getting it work to with my HDTV. It works with fine with the 21 inch HD monitors I have at the office.
    The TV is a Proscan Full HD 1080p, model 42LA45H. It is about 1.5 years old, and has been great up until this. It has 2 HDMI inputs, I've tried both.
    When I connect the HDMI out on the A500 to the TV, the A500 knows it is connected because it gives an alert. On the TV all I see is an Android icon in the middle of the screen with the text "720p?"
    Suggestions anyone?
    I know the A500 is only outputting 720p through the HDMI port. I've read online that this might be a problem with Android 3x. Does anyone know if this correct, or when this fix is due out?
    I considered returning the A500 and getting an Asus Transformer, but I read that they also only output 720p through the HDMI port. Do other Android tabs only output 720p on the HDMI ports?
  2. androidnewb
    androidnewb Member
    It sounds like your TV is asking if 720p is what you want to change the resolution too, since that's what the A500 pushes out. Did you try and select yes or something with your remote?
  3. elsuirad
    elsuirad Senior Member
    Currently on KSA
    SAMSUNG S5 Mini
    check your video settings.
    maybe you might missed some settings should be coming out when you attached your HDMI Cable in your TV.
  4. jak
    jak Member
    Acer A500
    I have checked the setting for the TV a couple of times. Even read the manual for the TV. I can't find any setting on the TV for the HDMI.
    Just restarted the TV with the A500 connected. Didn't make any difference.
  5. jak
    jak Member
    Acer A500
    Oh, I opened a ticket with Acer. Will update here if they provide useful info. So far they asked me to upgrade to android 3.1. I upgraded shortly after buying the a500.
  6. maxpower
    maxpower Member
    Canada
    Acer Iconia A500
    I have opened 2 Acer support tickets on the same thing. HDMI out does not work at all.
  7. phonegunner
    phonegunner Member
    slc ut
    A500
    I have had this problem...
    It was a bad (or inconsistent operating) cable..
    1 cable works with all my HDMI input TV's no problem...
    The other cable will not work with the HDMI input of the TV BUT it will work with the HDMI to Component adapter to the TV... (which actually worked out since all of the other 4 HDMI inputs are in use with other devices....)
    So... it might be the cable ....
    Ted...
  8. PeteDee
    PeteDee Member
    Australia
    Acer Iconia A500
    All my cables have worked just fine, sorry to hear you are having problems guys.
    Pete
  9. maxpower
    maxpower Member
    Canada
    Acer Iconia A500
    should it just be plug and play? Is there an app to test the port?
  10. HD87
    HD87 Senior Member
    US
    Acer Iconia A500 tab
    It is plug & play. Test different hdmi cables with different monitors.. If neither is projecting the image then its the tablet. Would make an insurance claim. It should have a 1 year warranty for hardware problems.
  11. jak
    jak Member
    Acer A500
    Update: Took the A500 into BestBuy today. One of the Geek Squad guys tried it on 3 different 1080p TVs. It worked great on all of them. Looks like my TV is the problem. Geek squad guy suggested the TV had old firmware.
  12. rkka93
    rkka93 Member
    Chapel Hill
    Iconia a500
    You might be in a similar boat I'm in. I have an old plasma that only does 480p or 1080p. I don't know why for the life of me you would do 1080p and not 780p, but that's the way it is.
    Searching on the web, I saw an article from May that said there is supposed to be an update to the Iconia to output 1080p (later in the summer). Anyone heard of that?
  13. PavtubeVideo
    PavtubeVideo Member
    many tablets claim supports 1080p video playback, but, according to user discussions, some 1080p video playback with issues, in this case, you may try converting 1080p to 720p, which looks no different
a500 hdmi not working
acer a500 hdmi
acer a500 hdmi not working
Acer a500 hdmi out issues
acer a500 hdmi out not working
acer a500 hdmi problem
acer a500 hdmi settings
acer iconia a500 hdmi problems
acer iconia a700 hdmi not working
acer iconia hdmi connection
acer iconia hdmi not working
acer iconia w3 tablet hdmi out not working
acer tablet hdmi not working
android a500 hdmi problem
android tablet hdmi issues
can the hdmi port on acer a700 iconia tab input video
hdmi problem iconia a500
how do i convert 1080p to 720p on my acer a500
how to hdmi acer tablet a500
settings hdmi acer tablet
