Acer Iconia A500 WiFi Problems
Discussion in 'Acer Iconia Tab A500 Forum' started by edm949, Sep 16, 2011.
  1. kindlife
    kindlife Member
    honolulu
    a500,i4s, evo, hpi7 17"
    Wierd to see this thread today as I am having a problem with acer accepting wifi tethered rooted evo. It sees it but won't accept it. Watched netflix this morning on the way to work. No problems. Now won't pick it up. Accepts linksys and visio routers at home no problem. Just wierd. Used sprint hotspot on the way home from work with no problems. Wifi tether working fine and a500 sees it just won't accept. Forgot and renewed it 5 or more times without success. Just keeps cycling. Always something.
  2. BobjGear
    BobjGear Member
    Florida
    Toshiba Thrive 10in 32GB
    Yes, This solution works well for all routers. Assign a static IP (away from the ones being automatically assigned) in your wi-fi setting on your tablet, and you won't have the disconnect problem anymore.
    -Regards,
    bobj
  3. tr777ple
    tr777ple Member
    usa
    acer a500
  4. igennie5
    igennie5 Member
    This is most common problem with acer tablets,all you have to do is to be close with the AP.
  5. diiorio
    diiorio Member
    Houston
    Acer A500 series
    Had that happen all the tiem with my old Belkin router. When I got a new multi band Asus Wireless N, it never looses it and always stays connected
  6. hacktik2663
    hacktik2663 Member
    This the most common problem with the acer tablets. I am facing the same issue.
  7. Douvie
    Douvie Senior Member
    Kyneton, Australia
    I haven't got a problem. Also I just want to correct some mis-understanding. Leave the tablet on DHCP. When you force the tablet to forget the connection and then reconnect, you can force the tablet to use a IP further away.
    The problem is that you will get devices clashing over IP addresses. Don't tell me it doesn't happen it does. Most of my IT calls are for this very reason. iPads and iPhones are the most guilty when it comes to snatching another devices IP.
  8. zahuti
    zahuti Junior Member
    I had the same issue....I reset to factory default and then changed wi-fi disconnect policy to the option ( when screen turns off)...I am able to view full movies without wi-fi disconnecting....hope it works for you.
  9. zahuti
a500 wifi fix
acer a500 internet connection problems
acer a500 problems
acer a500 wifi fix
acer a500 wifi issues
acer a500 wont update
acer iconia a500 wifi connection problems
acer iconia a500 wont update
acer iconia losing wifi connection
iconia wi fi problem
