After flashing will not start flytouch I Need Help
Discussion in 'Gome Flytouch Problems' started by kolipso, Dec 12, 2010.
  1. kolipso
    kolipso Member
    NULL
    People Hello!
    I do not know what to do with his flytouch IT worked fine until I flash it to version 1.8 that's when it hung up and no longer flashing not a single firmware The story is any attempt to flash the end hangs at boot time
    Pictures attached!
    What should I do? may be some other specific changes in faylk scriptcmd?
    Have any thoughts?
  2. kolipso
    kolipso Member
    NULL
    Guys, I've figured out with his flytouch
    Good luck
    Topic can be closed))
  3. probbiethe1
    Gilbert, Arizona
    what was the trick share it with us?
  4. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    I'm having the same problem...what did you do??
  5. mitchb
    mitchb Member
    Philippines
    Gome Flytouch
  6. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    Okay...I've taken mine apart.....and there isn't an internal microsd card. Is that the reason?
    I see 2 1GB ddr2 chips next to the wm8505+ chip
    Removable Processor board:
    Proc - wm8505+, 1037cd Taiwan, 2ja2016801 (comma denotes next line)
    DDR2 chips - Hynix kor, hy5ps1g831c, fp-s6 c 044v, mwhabjp3mc (when I look them up it says 1GB DDR2 800.....what??)
    Main board: (labeled m009b_v2, 20101115)
    Nand flash - Samsung 043, k9gag08u0e, scb0 (looking it up that's a 2G x 8 bit advanced flash chip by samsung)
    Lan chip?: VIA VT6113, 1034cd taiwan, 2ua3003671
    Audio Touchpanel codec: WM9715g, oaackai
    the other small chips having a hard time reading the numbers.....
  7. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    Is there any way we can get tipstr to come in here and read this thread?
  8. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    I have a huge problem....as I was taking it apart again.....taking the screen cable out of it's socket I forgot to disconnect the battery and my thumb pressed a little button next to the screen ribbon cable socket...now the power led light goes on when you press the power button but the screen doesn't come on at all....even if I long press the button (doesn't do a thing). Did I just brick it????
  9. tipstir
    USA
    COBY KYROS 7015 | 7015A
    I am here.. Why were you taking the tablet apart in the first place?
  10. keithwong
    keithwong Member
    NULL
    Wow...this is like answered prayer lol. Tipster, can you help tweak some of the ROMs for 128M pads? perhaps just post the amended scriptcmd file. Will that work?
  11. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    Screen was messing up a little (it would flicker sometimes while moving the pad)....when I took it apart I could see the ribbon cable wasn't seated properly. And while I had it apart I took note of the internals.
  12. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    I think I've Identified this as an eken M009. Pandawill is selling that model and the pictures are identical to this pad (even the symbols next to the plug sockets are the same)
    there's a rom on the eken homepage under downloads (ekengroup.com) called "m009 new" but unfortunately I can't try it at the moment since my pad is non responsive.
  13. Sagan2010
    Sagan2010 Member
    US
    Flytouch
    Anyone have any idea if I bricked it permanently or not?
  14. bilms01
    bilms01 Member
  15. xaueious
    Canada
    Argh why do they all look the same...
ekken m009b firmware
fly touch
flytouch
flytouch 8 hung up
m009b v2 20101115
