Aimlogic Mid c 070a keeps resetting. Help
Mo1
I've got a issue with the tablet constantly resetting back to chinese and wiping everything off including all the apps I download. What could be causing this and how do I fix it? Any help would be appreciated.
Mo1
The only things I don't loose when it resets is the music and movies on the sd card. Its getting really aggravating constantly having to download everything over and over for my daughter
atn
your data partition couldn't be mounted.
go to recovery (shutdown. hold MENU, then POWER for a few seconds) and choose 'wipe data' (volume down to change selection, then back button (?) to select). this should reformat /data and fix it
