android green guy stuck in start up. ...help
Discussion in 'Android Tablet Discussions' started by tables74, Jan 30, 2011.
  1. tables74
    tables74 Member
    Lake Wales Fla
    ANDROID MID TABLET PC 2.0 OS
    My Android stops in mid strem on start up. What might be wrong? Anyone have this problem also? Please help
  2. alcassetta
    alcassetta Member
    Oregon
    A8 Corte Pad
    My son and mine are on their way back to Shenzhen , China for a full paypal refunds, ,we tried every thing, the supplier suggested, nothing fixed the problem. Ours was a A8 Cortex 800mhz Freescale processor with android 2.2 7" model. Did you reset it?
  3. desfoo
    desfoo Member
    NULL
    what did you update/done before this happened?
  4. tables74
    tables74 Member
    Lake Wales Fla
    Did not do anything just charged it Android turned on it was fine till now?
  5. tables74
    tables74 Member
    Lake Wales Fla
    How do u reset a device w.no reset button?
  6. yoyodunno
    yoyodunno Member
    There might be a button combo that resets the device, and formats it.
  7. BernHardN
    BernHardN Member
    Holland
    winbest telechips 8902 based
    There might be an reset button in the mic. hole.
    at least mine has.
  8. sinister1
    sinister1 Member
    NULL
    Can you tell us which tablet you have. I have one of the cheap 1.6 Chinese 7" generic flytouch tablets and It will reset by holding power, and menu together for a few seconds.
  9. BernHardN
    BernHardN Member
    Holland
  10. jmac999
    jmac999 Member
    10.2 inch x220 superpad
    The 7 inch ones have a mic hole which you can reset through I believe
  11. Gr1m310
    Gr1m310 Member
    West Covina, Ca.
    Epad 7" Touch Screen Notebook Android Camera Tablet MID
  12. cjbaer50
    cjbaer50 Member
    Billings, MT
    google android os2.2 kernel 2.6.32
    There is a tiny pin hole by the head phone hole on mine.
adroid tablet stuck on android with green nan next to it
android green guy
android green guy stuck in startup
android green man stuck hard reset
android screen stuck on green android man
android stuck on green man
android tablet - green man stays on screen
android tablet freezes on startup
android tablet stuck at startup green
android tablet stuck on green man
anriod guy stuck
eklasse tab screen error just drppped the tab
epad tablet freezes on start up
green droid guy
help green android stuck in start
how to reboot eklasse tablet
mid806s reset
start up stuck on green android
tablet eklasse hang in logo
why when i open android it android green nan
