Android Tablet Will Not Go Into Recovery Mode
Discussion in 'Android Tablet Q&A' started by hittinit, Nov 24, 2012.
  1. hittinit
    hittinit Member
    16GB 1GB DDR3 10" Inch Android 4.0 Capacitive Tablet HDMI Dual Camera A10 Core
    I just bought a new 16GB 1GB DDR3 10" Inch Android 4.0 Capacitive Tablet HDMI Dual Camera A10 Core. OS i think is 4.0.4. i am trying to put it in recovery mode, power button and vol down when i do that, it just boots up normally. Then i go into settings and there is a recovery mode section, i press that, it reboots but not into download mode. It will reboot into a different recovery mode that only gives me one option "system reboot now" no matter what i have tried i cant get it into recovery mode, i have read where it says to press vol up and power button still nothing, it seems as though my tablet wont respond to the vol up or down along with power button. Not sure what i can do... any help would be awesome, thanks in advance
  2. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    No ideal what you are doing, the tablet is working as expected, This "It will reboot into a different recovery mode that only gives me one option "system reboot now" is recovery mode. Your tablet correctly boots into recovery, so what are you trying to do, apparently not get into recovery mode.
  3. hittinit
    hittinit Member
    i am trying to put it in recovery mode, or i should say a recovery mode/ downloading mode to root my android tablet
  4. hittinit
    hittinit Member
    since i am new to tablets, from what i read i need to put it in a recovery mode to have ability to download in order to begin to root my tablet and since i cant get past that, i cant go any further unless there is a diff way to go about rooting
  5. vampirefo.
    Huntington WV
    Honestly I have no clue what you are doing, I root and develop for all types of androids, never heard of what you are trying to do.
    Are you trying to flash livesuite?
  6. vampirefo.
    Huntington WV
    Most tablets are rooted via adb, which doesn't require any mode just requires adb to be installed and working.
    Can you post a link to where you got your tablet, so i can see what type it is.
  7. vampirefo.
    Huntington WV
    Most allwinners come rooted out of the box, are you sure it's not rooted?
  8. vampirefo.
    Huntington WV
    adb shell
    su
    post output.
  9. hittinit
    hittinit Member
  10. vampirefo.
    Huntington WV
  11. hittinit
    hittinit Member
  12. hittinit
    hittinit Member
    ok how can i find out for sure if its rooted or not, is there something in settings i can look for to find out for sure?, Also is a rooted tablet the same thing as a jailbreak on an iphone? thanks
  13. vampirefo.
    Huntington WV
    download terminal from market
    type
    su
    if rooted you will see
    yes rooted is same as jailbreak
  14. hittinit
    hittinit Member
    do you have a direct download link for Android Terminal Emulator, its not letting me download it because i have access some white shopping bag icon on my tablet, thanks, also i did a factory reset on my tablet when i was having problems would that delete the root part if it was on there when i receivec the tablet?, thanks in advance
  15. hittinit
    hittinit Member
    ok i was able to download it, but the msg said email was sent to my device how do i retrieve it from my tablet and download it??, thanks
android system recovery zh&k
chromo inc tablet reset
chromo tablet recovery mode
chromo tablet reset
inar recovery mode
naxa core recovery mode
royqueen tablet boot into recovery mode
tablet 24 inch android
tablet android system recovery
tablet wont boot into recovery mode
