Anyone with zenithink E98? NEED HELP!
bumskee
Hi.
I think this one might just do the trick for me..
just need to check if this runs Autodesk sketchbook mobile.
It's the ONLY reason I am needing a tablet and would be great if someone with the tablet can confirm this tablet works with "Autodesk sketchbook mobile"
And the 2 point multi touch works too? (zoom in and out)..
thanks!
bumskee
thanks,
good to hear the multi thingie will work,
sketchbook mobile has a minimum requirement, it's 1ghz and 512mb ram. just wanting to make sure E98 satisfies it, i read somewhere the cpu is max at 1ghz.. and not sure how that would effect running sketchbook mobile. if it even runs in the first place.
