Aoson M19; thoughts, rooting & firmware & now need firmware OR build.prop
Transkryption
Gingerbread rooted it easily...
After rooting using Root tool kit I installed Cyanogen DSP and 'fixed market links'
It now wont get past boot screen.
One I can connect with ADB removing Cyanogen DSP should be easy.
as for fixing market links I need a build.prop file (probably rom this device.
If anyone can help...
sw6lee
hi i have a question, do you know if aoson m19 will be updated to android 4.0? i would like to buy it if so.. thanks a lot.
tab28
hi i need your help please... i accidently formated sd card of my aoson m19 tablet.. now its not working at all. i think the firmware is deleted.. when i conect it to my laptop aoson screen appears then the device resatrs and this process goes on. can u plz help? thanx
vliespinda
Hi
I have this tablet running on android 4.0.3
I have trouble to install apps from googleplay, not all apps but enough to ask for help.
Can this be fixed when i will root my device?
Where can i download apps to root my Aoson M19
i will be grateful for anyones help
userbe1155
697
55
Not sure about your tablet make but many are having problems with some apps. I don't think its device. Many apps aren't ready for ics just yet. I think in time this will change.
