Audio player recommmendation?
bmb
I would like to find an audio player that allows for the creation and modification of playlists, but it doesn't appear that the default audio player that comes with the Nook tablet does. Is anyone aware of an app that allows that? I haven't tired rooting the tablet (although I am considering the n2a card), so it would have to be something I can get from the Nook app store.
Thanks in advance.
Temetka
23
I haven't seen any other music players in the Nook Store. There are ones for streaming but to my knowledge they don't play side loaded music. I'd recommend winamp for you if you do get a n2a card though.
J515OP
Super Moderator
5,172
899
Can't you still side load apps other than from the Nook Store? There are definitely rooting and bootable SD card options now if not. At that point it is just a matter of picking your favorite from the many in the Amazon Appstore and Google Play Store. Winamp is a good example.
