Aurora ICS 4.0.3 Mobiz V.2 Modified to Work on Coby 7042 and 8042
Discussion in 'Coby Generation 3 Development' started by vampirefo., Jun 16, 2012.
  1. vampirefo.
    vampirefo. Senior Member Developer
    Huntington WV
    Leagoo Lead 1 ZTE OPEN C, Coby 7065, Coby 8042, Coby 9740
    Most roms out there could be modified to work with Coby, I am not going to do all that work though, when I fine a nice looking rom like this one I do plan on modifying it, giving credit to the author as well as a link to the original rom thread.
    You need to have cwm recovery already installed, place on sdcard and boot into recovery use cwn to install 7042_Mobiz_V.2.zip #note always have at least one good backup before flashing any rom.
    this changes sdcard mount points, sdcard will be the small micro card you insert in tablet, internal will be /mnt/sdext
    to read about rom.
    [ROM] Aurora ICS 4.0.3 Mobiz V.1 by wasan007 (Based on Feiyu 0515) - SlateDroid.com
    7042 download below #note this is for 7042_boot and not 7042_boot1
    http://www.mediafire.com/?lwss5tp638xyfyp
    I am currently testing a version for 8042 haven't uploaded it at this time, there will be two versions for 8042, one installs to tablet other will install to sdcard for those that are using boot_ds.img.zip , eg running /system and /data from sdcard. the latter is my preferred method.
    credits go to
    wasanoo7
    added init.d support zip should work on any android.
    7042_init.d_support.zip
    • Like Like x 10
  2. vampirefo.
    Huntington WV
    I have just uploaded the two 8042 versions.
    You can if you want do a factory restore before installing if you like, so you would have a fresh install, that's up to you
    to install place on sdcard boot into cwm and install.
    8042_ds_Mobiz_V.2.zip
    .8042_Mobiz_V.2.zip
    • Like Like x 2
  3. paintballeralex07
    paintballeralex07 Senior Member
    Coby Kyros 7022
    Will this rom work on a 7022?
    Sent from my T-Mobile G2 using Tapatalk
  4. paintballeralex07
    Coby Kyros 7022
    I've been trying to port it but I get a force close on the update service then it reboots
  5. Patchirl
    Patchirl Member
    Coby 9742
    Would this work with the 9742?
    There has been no custom roms for it yet apart from a rooted with market image AFAIK.
    Thanks....
  6. vampirefo.
    Huntington WV
    Neither of these version would work well on a 9742 most likely would boot and run just need minor fixes, seeing the 9742 dump I looked at, is so close to the 8042 modifying the 8042 version to work on the 9742 shouldn't be very hard.
    • Like Like x 6
  7. vampirefo.
    Huntington WV
    The 7022 isn't an allwinner, porting is possible but time consuming, I have replied to your pm hopefuly it works out for you.
    • Like Like x 2
  8. rposlp
    rposlp Member
    how can i know if i need the 7042_boot and not 7042_boot1? where can i see what touchscreen is in my tablet? and 7042_boot is for what touchscreen? Thanks
  9. vampirefo.
    Huntington WV
    7042_boot is for ft5x 7042_boot1 is for goodix
    Easiest way to tell is use dmesg.
    You can use adb or download a terminal from market
    busybox dmesg | grep ft5x
    or
    busybox dmesg | grep goodix
    • Like Like x 2
  10. rposlp
    rposlp Member
    i couldnt make the grep command, it says not found, but i execute dmesg only and i can see many lines saying ==ft5x_ts_resume==
    i believe my touchscreen is the ft5x right? thanks for the help
  11. vampirefo.
    Huntington WV
    Correct you have ft5x.
    Try this command
    busybox dmesg | busybox grep ft5x
    • Like Like x 2
  12. rposlp
    rposlp Member
    that command works "ctd_detect: detected chip ft5x_ts at at adapter 2, adress 0x38"
    can u tell me why i need to flash 7042_boot and not only the 7042_update? i already made a dump of stock firmware. i just dont want to mess around with this tablet cause i did the livesuit thing earlier on another one and i had to exchange it cause of the reboots. thanks a lot for your work
  13. vampirefo.
    Huntington WV
    The 7042_boot provides permanent root, and forces adb to su permanently. Coby has modified their boot.img to prevent permanent root. So I undo what Coby did.
    • Like Like x 8
  14. rposlp
    rposlp Member
    nice.. and what rom is better? (less bugs) the one in "linux users" thread or this one? its possible to install apps on the microsd card? any of this roms use another tablet fingerprint to make our coby more compatible? thanks a lot
  15. rposlp
    rposlp Member
    wow i flashed 7042_boot.zip from the cwm and im stuck on coby logo. what hapened? thanks
    edit: installed the 7042_update.zip and hes alive again. uff ;)
coby 7042 aurora
coby 7042 mobiz
coby crane 8042 rom
coby mobile system modified
error mobiz root
