Hello there ! Recently I have been trying to connect to my wifi with my CNM 7 tablet, however, i keep receiving the message : 'Authentication Problem'. I have tried all these solutions : Turning tablet on and off Turning Router on and off Turning WiFi option on tablet on and off Resetting the tablet (three times) Resetting the router Retyping the password numerous times None of the above work ! I know that the password for the wifi haven't changed because all my other gadgets can connect to it ! Please help ! The following link is the tablet that I have ! CNM 7 INCH TOUCHPAD MULTI TOUCH TABLET 8GB WI FI ANDROID 4.0 - BLACK | eBay
Welcome to the forum I assume by reseting the router you meant back to factory default? If so I would try going to a public WiFi hot spot and try to connect. Normally I would have said the problem was the type of security in the router but if you did a complete reset you may have a hardware issue with the tablet.
You indicate all your other gadgets connect to it, maybe you have maxed out the number of gadgets you can connect to the router.
Thanks for replying guys ! I did reset the factory back to factory settings!! Before my tablet started to get this problem i was still able to connect to the internet with it ...even with all my other gadgets connecting to it ! I hope its not a hardware problem xD ! but any other ideas/solutions ?
This is just a WAG but have you tried the default password for the router at the vendors website to see if it will work?
