I have a laser android 2373 tablet which has been working well until i received notification of 2 threats on it which have turned up before.At that time I took it back to where I had bought it from and they reset it back to factory settings, this is what I did with this latest lot. Now I can not connect I keep getting Authentication problem.What do I do can any one help please. I am with Vodafone here in Nz
Welcome to the forum We may need a little more information. Are you connected by way of 3G or 4G on the tablet or are you trying to connect to WiFi?
OK then, check this thread http://www.androidtablets.net/threa...onnected-if-having-problems.44790/#post232332 Failure to authenticate normally would be that you need to change the type of security, possibly to WPA/WPA2 if you are using WEP, or you may have an unusual passcode, one that Android doesn't care for, but that link should provide some clues.
