Battery Booster is a powerful battery boosting tool and power management application specially designed for Android smartphone (with Homescreen Widget Support). Based on system specifications, Battery Booster provides the most accurate information on your battery charge, which includes the real-time battery capacity, temperature, voltage, etc. An auto-updating live chart allows you to visually track your battery usage. ****************************************************************************************************** New Features in Version 2.3 (Oct. 27, 2010) -Add "On Device Unlock" option to open WiFi/BT when device is unlocked -Smart Battery Saver function optimized now fully compatible with Memory Booster -Speed up operation performance -Screen Brightness setting readjustment ***************************************************************************************************** A variety of battery boosting techniques is also embedded in Battery Booster to boost up your batterys running time and maximize battery life. For example, Battery Booster will remember your last battery calibration time, notifies you when a monthly calibration is due; it turns off WiFi and Bluetooth when your Android smartphone is on low battery or when your device is locked (The status of WiFi or Bluetooth will be saved and restored after your device is unlocked). At the same time, its innovative Smart Battery Saver can save extra battery by killing idle processes running in the background (Based on Memory Booster Android RAM Optimizer) A must-have battery booster for Android users, enjoy! Features: Real-time battery status (capacity, temperature, voltage, and charging status, etc) monitor and battery usage tracking Homescreen widget support (Add to homescreen with Menu -> Add -> Widgets -> Battery Booster) Shortcuts to WiFi/Bluetooth/Screen Brightness/Screen Timeout settings Battery Calibration Notification to maximize your battery life span Settings to turn off WiFi/Bluetooth when device is locked. (The status of WiFi/Bluetooth will be saved and restored after your device is unlocked.) Settings to turn off WiFi/Bluetooth when your battery is low. Settings to enable beep and select beep tone when your battery is low. Save more battery with built-in smart task manager (Based on Memory Booster Android RAM Optimizer) Screenshots: This is one of our popular Android apps, you can download it for free and more suggestions would be appreciate. Thanks
