Battery Fail?
rmhartman
I hope there are still people watching this forum.
I have been having a problem with the 78 that I have not seen mentioned elsewhere on the web. It works fine while it is plugged in, but as soon as I unplug it, it goes dark. The battery monitor app/widgets report that the battery is charged and in good condition. Oddly, I have a "phone test" app that does not recognize that it is plugged in!. I would expect that, even with a failing battery, I would have _some_ life after unplugging ... if only five or ten minutes. Any suggestions?
pbrauer
3,649
561
I had the same issue on mine, and after weeks of fiddling and various other things it turned out to be the battery. I actually got this confirmed from Avi at AugenUS before they went out of business, so you may well be out of luck, sorry.
Sent from my gTablet using Android Tablet Forum
rmhartman
Yeah, I figured it was the battery. Sorry it took so long to respond to your response. I was wondering whether you know of anywhere to get a replacement battery?
